Question about Cartoni Photography
The auto release lever is stuck on my Cartoni Alfa II
Hi, I can't seem to get the auto release lever to move so I can lock the camera onto the tripod.. Any suggestions?
Thanks
SOURCE: Manfrotto Tripod Ball-grip Head 322RC2
If you look on the ring that goes around the ball, on the side by the red tension gauge, you'll see an indentation. It is just barely visible on the product shot above.
In the hole, you'll find what looks like an odd shaped bolt. It is actually a threaded post inside a nut.
Use an Allen wrench (hex key) to tighten this post.
Be careful though, a little tension here goes a long way. You should probably turn it no more than 1/8 to 1/4 turn and then test it. If it still isn't tight enough, repeat until you are satisfied.
You should probably also talk to a trained technician at somepoint to see if the loosening is indicative of a larger problem. I really wouldn't know one way or the other. I just discovered the calibration post by taking mine apart.
Posted on Nov 25, 2007
Agent Allan
  • 480 Answers
SOURCE: Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Posted on Apr 16, 2008
SOURCE: need a quick release plate for Dynex tripod 60
The Velbon QB-4W Quick-Release Camera Platform is a nearly identical replacement for the plates that come with the Dynex DX-TRP60 tripod. You should have had a spare in the bottom of the tripod bag when you bought the unit. The Velbon QB-4W is available at many on-line sources for about $5.95.
Good luck,
Swarf
Posted on Nov 20, 2008
  • 24 Answers
SOURCE: quick release for ambicom v 0552 tripod
Try www.TripodQuickRelease.com They have two sizes listed. If yours is the 41mm or 45mm opeing they can help.
Posted on Feb 10, 2009
  • 7 Answers
SOURCE: I need the camera plate for a Titan II, QT II-950,
15 bucks at the following site:
http://tripodquickrelease.com/Quantaray_Titan_II_Quick_Releases.htm
Posted on Jul 12, 2009
In the Gitzo GH2750QR head the quick release plate got stuck. What to do?
Is it the plate itself that is stuck, or is it the lever that needs to be moved to release the plate ? From a brief look at images of the item, it looks as if there is a small locking lever connected to the actual release lever - has this been freed, or is it that which is stuck ?
Nov 13, 2016 | Gitzo Gh2750qr Series 2 Magnesium Off...
I need a guide pin for a cartoni b511 quick release plate and i can not find one
If you are looking for a non-threaded 'locating' pin to stop smaller video cameras from twisting on the plate...Cartoni does not make one!!! You will either need to mickey mouse something or purchase a new camera plate from another manufacturer that offers this. Luckily this plate is a standard 'Euro' plate used by many video tripod manufacturers. For example, I know the Miller cat# 860 will take a cat# 493 DV carriage which provides not only the 1/4-20" screw but also the locater pin as an assembly.
peter
Jul 02, 2012 | Cartoni B511 Quick Release Plate
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
May 20, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
Seat Position Cant be moved
The manual lever to release the seat is supposed to have a spring on it to return the release lever to the lock position, if the lever does not spring back when you let go of the seat adjustment lever then you know there is a missing, dis-connected, or broken return spring.
If this is the case try putting the seat where you want it to be and make sure that the adjustment lever returns to the lock position, now check to see if the seat will lock in with the adjustment lever in the lock position.
If it does lock in repair or replace the return spring.
Make sure that the adjustment lever is attached to the locking linkage and it does move the locking mechanism.
If it still does not lock into place then there is something wrong with the seat locking mechanism, and some WD-40 sprayed onto the seat rails and track might release a stuck mechanism, and if everything seems to be working alright, and you can see that the locking mechanism in the seat rail is moving in and out of the lock position, then the locking tabs are most likely sheered off and you will need to replace the seat.
Also look under the drivers side seat and compare the lever position and the linkage connections with the passenger side seat, and make sure that it is all operating like the drivers side seat.
Apr 28, 2010 | 2000 Renault Sportwagon
Canon A-1, film advance lever and shutter release
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jun 24, 2009 | Nikon FA 35mm SLR Camera
Mamiya RZ 67 lens is stuck on body
This is likely because the shutter has not been cocked all the way. Return the lens to the fully locked position and advance the film with the lever all the way down to reset the shutter. If it still doesn't work, move the lever to M for multiple exposure, make sure the back is aligned and trip the shutter release. Then fully **** the shutter again by pressing the advance lever down fully and again until it is reset. Then try to remove the lens again.
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Film advance lever.
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
Sep 16, 2008 | Nikon FE 35mm SLR Camera
The film won't advance
Look on the shutter release button, there is a lock switch on bottom of the button. turn it toward the prism.
Jul 08, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
Nikon d40 digital camera
When the camera is in auto focus mode, it will not take the picture until it locks onto a subject. If there is not enough light, the camera will "hunt" for something to focus on. Since it can't define any edges, it won't allow the shutter to release.
The D40 base model does NOT have a powered focus lever for autofocus, so if the autofocus is not working, suspect the lens.
Mar 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Photography Logo
59 people viewed this question
Top Cartoni Photography Experts
Tony
Are you a Cartoni Photography Expert? Answer questions, earn points and help others
