Question about HP OfficeJet G55 All-In-One InkJet Printer
Officejet G55xi tells me to remove and check black cartridge. I have done so several times with the current cartridge. Same thing happens-check cartridge. I installed a new, fresh black 45 from an office supply store-was not a reloaded cart-was a HP boxed cart. Cleaned both the contact areas on the back of the cart and the contact pins on the cart holder. Still the same check cart.
SOURCE: Hp Office jet print cartridge error
I have a 7410 that is 16 months old with the same problem. It is not a broken spring. Spent over an hour on chat attempting to trouble shoot. HPs only solution was to sell me an "upgrade" for over $300 (which is more than I paid for this piece of junk.)
I expect "top of the line" products to last quite a bit longer than that. The worst thing is that with this error popping up, it is absolutely useless for anything else like scanning or outbound fax.
It should be called an "all or nothing" printer.
Posted on Feb 29, 2008
  • 327 Answers
SOURCE: remove and check color cartridge
the internal circuit of the printer which connects the colour cartridge is gone faulty so this error.that internal circuit needs replaCEMENT.thanks
Posted on Dec 15, 2008
SOURCE: HP psc2175 remove and check cartridge
Make sure you run the procedure to have the printer cartridge align after reinserting it.
Posted on Mar 13, 2009
SOURCE: Continue to receive "Remove and check black cartridge" message
Gotta love the internet!
I had the same problem...I seriously considered getting a new printer since I've had my faithful 5510 AIO for like, six years...but what I did was grab some witch hazel and a q-tip. Dipped the q-tip in, wiped down all copper contacts on the carriage and also on the print cartridge...blew on it to air dry...popped it back in and viola! It's back to normal.
Posted on Jul 09, 2009
  • 68 Answers
SOURCE: my officejet x40xi, tells me incorrect color
Hi, please find the solution of your issue on below HP website: http://h10025.www1.hp.com/ewfrf/wc/document?lc=pl&dlc=pl&cc=pl&product=14438&docname=bua02058
Posted on May 03, 2010
I replaced the black cartridge and the machine asked me to align.. I have done this several times and the machine will still not print in black. What do I do?
You might have to remove a strip first that comes with the new ink cartridge. Or, perform the function that cleans the printer heads
Hope this helps. :)
Oct 02, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
My HP Officejet 4500 keeps telling my to align my printer cartridges and I have done it several times. After I align them and print something it requires me to align them again.
Try removing the cartridges, closing the printer, and disconnect the power. Let sit for at least 10 minutes, then hook up the power, wait until it stops making noises, the reinstall the cartridges, black first, then color, and if the alignment comes up again, press cancel. This should remove the error.
Sep 30, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Remove and check cartridge on right. I have removed it several times but still comes up with message and will not work
All I did was replace my black ink cartridge with a new one and it works. You think it would say replace ink cartridge instead of remove and check cartridge on right. Good Luck.
Aug 14, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Replaced ink cartridge 56 and black print text is
Remove the cartridge and use a damp paper towel, wipe the bottom of the cartridge several times. Each time you wipe you should be getting black streaks on the paper towel. After manually cleaning the cartridge nozzles you will need to use a new tower and wipe the contacts on the back of the cartridge. When this is done reinstall it and run a cleaning and then an alignment procedure from the printer software. You should be printing good again.
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Remove and Check Cartridge
One of the cartidges you have purchased is faulty.
you can reinstall the empties one at a time as a process of elimination to determine which new cartridge is the problem
Jun 06, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I changed out the cartridge and the error comees back saying to check cartridge on right. I've done it several times and can't see thing wrong with what I done.
I would try a brand new HP black ink cartridge. Those ink cartridges are not made to be refilled according to HP. If you were to call HP and tell them you had a refilled cartridge they would stop the service call right there and tell you to try a genuine HP cartridge.
Nov 12, 2008 | HP Office Equipment & Supplies
Cartridge problem
1. remove the cartridge and check the cartridge no. is it supported or not
2. if its supported then clean the cartridge contact and carriage cartridge contact with clean cloth and then check
3 some time what happen if color carteidge sircuit is gone bad then also this issue is comming so please check with new pair of cartridge
if issue same after done these steps then go to the neareast service center might be carriage pcb or flux cable or logic pca one of these part might be goes faulty
Nov 03, 2008 | HP Officejet 4110 All-In-One InkJet...
HP OfficeJet G55 All-In-One InkJet Printer Logo
77 people viewed this question
Seeker5211
Seeker5211
