Question about Electrolux 16.8 cu. ft. Upright Freezer Professional E32AF75FPS
I have model number and serial number of an electrolux freezer... all i need is the cubic feet of it. is it hidden in one of the numbers? Model number lffu1424dw4
How do I work out the storage capacity in liters for my fridge Frigidaire FPC523TEW1?
Hello Howard;
My name is Peter. I am a retired field service refrigeration technician.
Near the top side wall inside your freezer there is a label that gives you the exact cubic feet. Your model number has a rounded off cubic of 23.
So,
23 Cu.Ft. x 28.316 = 651.218 Liters.
Mar 13, 2015 | Frigidaire Freezers
What is the fridge capacity in liters?
Hello Howard;
So,
Mar 13, 2015 | Freezers
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
What size (cubic feet) is the Frigidaire Freezer Model # FFU17FC4CW0
I am going to guess that it is going to be around 17 cubic feet since that number is in the model number, at least that is how current models are labeled. Here is a link to a copy of the owners manual if you need it.
FFU17FC4CW0 FRIGIDAIRE FREEZER Manual
Here is another link to a page where I looked up the age of your unit and it will give you an idea where to look that up as well.
Appliance411 Service How old is my appliance Age finder date of... Hope this helps!
Feb 18, 2015 | Frigidaire Freezers
What size is a frigidare 297080400 upright freezer
Hello friend, thank you for your post!
In order to provide you accurate information could you provide me with your model number please? Normally you can locate the serial tag (which lists your model number) on the inside wall of your freezer. With that information I can provide you with the cubic ft. of your freezer. I look forward to helping you further. -Matt
Oct 04, 2014 | Frigidaire Freezers
I have a model number 198.8171985 and serial number E60315479 chest type freezer. The freezer just died. I have had the freezer from 24 plus years. I need to know how many cubic feet this freezer was....
Sorry to read about your problem, I hope this helps you out.
just take your tape measure..measure lenth,width,height... inside of compartment's LXWXH = cubic feet
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Kenmore Freezers
I am looking for the specifications like cubic footage on my chest freezer
The model number indicates the cubic footage of the freezer.
Example...model number xyz186xxww.,would be 18 cubic feet.
Post your model number on this thread for an exact conversion.
Sep 18, 2010 | Freezers
Need info on chest freezer serial number 48H2091PSSO-12902566 We don't know the brand or the cubic ft. of it. It is at least 30 yrs. old. Any information you can find on it would be very helpful. Thanks....
A freezer this old will be difficult to find any information on.
There is another number that you might have more success with. Look at the back of the freezer, and there should be a removable plate that will allow access to the compressor. There should be a manufacturer's tag on the compressor with model#, serial#, date of manufacturer, etc for the compressor itself. With the freezer being as aged as it is, the compressor manu. may not have information there either.
Cubic feet can be eyeballed, or measured out. take a tape measure and measure the width of the interior compartment. Then measure the length, and height. For this purpose, ignore the hump or box where compressor sits. Length * Height * Width = cubic feet (if you measured in feet). If you want a more exact number, also measure the compressor hump as well, and subtract that number from the first.
Good Luck!
Nov 02, 2009 | Freezers
I need to know the cubic feet of my upright frost free frigidare freezer Model # MFU17F36W6
get a measureing tape measure inside dimensions multiply them together eg: a freezer with an inside dimension of 2' X 2' X 3' would equal 12 cubic feet if want an exact value measure in inches 24" X 24" X 36" = 20736 and divide by 1728 will give you cubic feet cool eh.. where did I get the 1728? (12 X 12 X 12) =1728 converts cubic inches to cubic feet Good Luck let me know when you pour that cement pad for under your shed I tell you how many yards to order
Oct 23, 2009 | Freezers
How many cubic feet is this freezer
After looking over their website, which is not very helpful, it appears that it would be approximately 5.0 to 5.2 cubic feet. It seems that in most cases, the model number contains the size. Check it out at Danby.com
Hope this helps.
May 18, 2009 | Freezers
Electrolux 16.8 cu. ft. Upright Freezer Professional E32AF75FPS Logo
129 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
