Question about GE Spacemaker JVM1640SJ Microwave Oven
We just lost power on the spaccemaker microwave jvm1630wkco2 and yes I've checked the plug. It is approx 4 years old. Thanks for you assistance Evelyn Carver
My Panasonic Dimension 4 microwave/convection oven (NE9870) is dead. It was running, produced a small popping sound and is now completely dark. I've tried alternate electrical outlets and there...
Ken,
Usually there is an internal fuse and that is probably your problem. You will need to take off the outside cover of your microwave and then look where the power cord goes into the back of the unit. Look for the black wire coming out of the power cord and follow it. It should take you to the fuse. Hope this helps!
Dec 16, 2014 | Panasonic NN-T888S Convection/Microwave...
Microwave runs but will not heat(unit is approx. 5yrs old)
the problem may be with your thermostat check that ,and repair it
Jul 03, 2008 | Microwave Ovens
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
F2 Error
F2 is a membrane switch error.
1. Unplug microwave oven or disconnect power.
2. Replace membrane switch.
3. If problem persists, replace electronic control.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
The answer to your question is YES. I would venture to say the PART is - but not the labor. You would need to read your warranty to confirm.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2009 | KitchenAid KHMS155L Microwave Oven
Panasonic 1250 watt microwave approx 5 yr old. the oven is completely dead. checked in other outlets. no power to oven
something burned out, has there been a thunderstorm lately?
if you get a new one, plug it into a surge protector.
Jul 16, 2009 | Panasonic NN-H504WF Microwave Oven
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
83 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
