Question about Whirlpool AWOE8748 Front Load Washer
Service light came on our whirlpool washing machine AWO/D4505 and we are wondering what we have to do
    New Friend:
Whirlpool WFE1070BD service light on
Posted on Apr 07, 2017
  • 61 Answers
SOURCE: whirlpool washer
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
Posted on Jan 20, 2009
canbruce75
  • 1776 Answers
SOURCE: Problem with Whirlpool washing machine - AWO/D 4705
The first thing to check is the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the opening on the water inlet valve and make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Test for continuity. A lack of continuity will mean a bad solenoid and the valve will need replaced.
If the inlet valve checks out alright, then the next place to look would be a malfunctioning water level/pressure switch. It is a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. Make sure there are no obstructions in or damage to the plastic tube. The switch can be tested for continuity in the same manner as the water inlet valve solenoids. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 15, 2009
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
SOURCE: how to reset service ligth
whirlpool awdo/d 4505 flashing service light
Posted on Feb 03, 2011
SOURCE: MY WASHING MACHINE WHIRLPOOL AWO/R 5206 HAS A
whirlpool awo/r 5206 service light on
Posted on Mar 28, 2011
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Feb 22, 2012 | Whirlpool Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
The clean water pump is flashing on my whirlpool awo/d4505 washing machine where is the pump and how do i clean it ?
There should be a access panel on the front of the machine at floor level.
This will have a filter which you need to clean. This filter is on the input to the pump.
Feb 03, 2010 | Whirlpool Washing Machines
Whirlpool awo/d4505
Change the filter material.
Jan 20, 2009 | Home
Whirlpool washer
Jan 20, 2009 | Whirlpool Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWOE8748 Front Load Washer Logo
2,558 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
