Question about Logitech Classic 200 DH968019 Keyboard
De activating num lock key only enables cursor movement in four directions. how do you get the number pad to enter numbers?
  • 4 Answers
This is a Windows feature called "mouse keys", it can be disabled by using the shortcut left-alt+left-shift+num lock.
In Windows 7 mouse keys settings can be found by following Control Panel\All Control Panel Items\Ease of Access Center\Set up Mouse Keys
Posted on Jun 26, 2011
The numeric key pad on my keyboard does not work
There's usually a Numlock key that turns off the cursor movement and turns on the numeric keys. If it doesn't say "Num Lock" or something similar, you might need to press the Fn key with the F1-F12 key that looks like a numeric keypad. Pressing the Shift key while pressing a number on the numeric keypad should give a number output if the Num Lock is turned off, the cursor movement if Num Lock is on.
Jan 25, 2018 | The Computers & Internet
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Number pad on right side of my lenovo model 2558 is not working
Try pressing the "Num Lock" key to enable digits - press again to have it provide cursor direction.
Mar 06, 2015 | Lenovo Computers & Internet
I'm trying to use the num lock to input numbers, but the function doesn't work unless I have num lock activated and also have the fn key constantly pressed. How can I fix this problem? Once I activate...
On some models, pressing Fn and F4 key will disable/enable Num lock on latitude.
On some other Dell laptops, a BIOS setup menu selection must be made when turning on the laptop to enable it to work.
Dec 26, 2017 | Dell Latitude 2110 Notebook
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
CAPS WORK BUT LIGHT DOES NOT COME ON
Step 1:
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up. You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2. Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock. Create a Num Lock Script Configure a script that runs to automatically change the Num Lock state. Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code "set WshShell = CreateObject("WScript.Shell") WshShell.SendKeys "{NUMLOCK}" Save the file as "numlock.vbs," including the quotes to change the notepad file to a script. Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default. For a single user, copy it to their startup folder instead of All Users. Enter the BIOS Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings. Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS. Common keys include "F1," "F2," "Del," "ESC" or "F10." Consult your computer's documentation for specifics. Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot. Enable in Linux Linux is an alternate operating system. While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux. Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
http://support.microsoft.com/kb/314879 How do I enable the NUM LOCK key for the logon screen http://support.microsoft.com/kb/154529
Feb 25, 2013 | HP Pavilion Computers & Internet
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
When i plug in the number keypad the numbers do not work and the number pad acts like a cursor director. For example in ms Excel the 8 moves up 6 moves right etc. How do I turn on the number mode?
Hane you enabled the Num Lock key?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 23, 2010 | Sakar iConcepts Notebook Light and Numeric...
KEY PAD LOCKED ON SO LETTERS COME UP WITH NUMBERS UNLESS YOU HOLD FN BUTTON DOWN CAT WALKED ACROSS COMPUTER WHAT DO I DO
It seems the cat activated the Num Lock key.
To deactivate it press simultaneously Fn +
Num Lock key.
The num lock key will be marked with 'Num Lk 'or with a a key pad icon the same colour of you Fn key.
Sep 06, 2009 | Computers & Internet
Logitech Classic 200 DH968019 Keyboard Logo
127 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
