Question about Frigidaire GL30LKEC (LP) Grill
How do I change the burner on the gl30ng natural gas bbq
How do I change the burner on the gl30ng bbq
5 Suggested Answers
SOURCE: no gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Posted on Dec 22, 2008
SOURCE: 'Downunder' burner not working (2 burner model)
i need drivers for my lg k750 telephone
Posted on Mar 21, 2009
ldaala
  • 65 Answers
SOURCE: How do I change a natural gas barbeque burner
most of the burners are just a slip joint so all u would have to do it pull or take a hammer to it and it should remove pretty easy after that good luck
Posted on May 26, 2009
  • 3081 Answers
SOURCE: changing my bbq from natural gas to lpg, I got a
no nat gas reg runs at 4inchwg lpg runs at 12 inch wg
Posted on Jun 04, 2010
I would like to convert a grill that was used on natural gas back to propane. Can I just purchase a regulator and hose and be good, or do I need to change anything else on the grill?
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
Can't find a natural gas regulator for a BBQ Galore 4 burner slide in grill. Believe it is a SST ( or sts) Turbo model. Any suggestions on what might be a valid substitute? Grand Hall ( the parts...
I assume you have already check with BBQ's Galore ( 800-752-3085 ), as they usually stock conversion kits, if that particular model is approved for conversion. Also, you will need 4 new Natural Gas Burner Orifices. The Propane ones will not work satisfactorily, if at all.
Hope this helped and Happy Grilling!!
Jun 28, 2011 | Barbeques Galore Turbo STS 4-Burner...
I have a Turbo Elite 3 burner barbecue. Want to convert it from propane to natural gas. Where can I get a conversion kit?
Your best bet is BBQ's Galore. Since it's their grill, if there is a conversion kit for that model, they'll have it. However, not all gas grills are convertible from one gas type to another.
Apr 01, 2011 | Grilling
I have a natural gas used built in bbq and want to change it to lp barbecues galore 167935
Contact BBQ's Galore either online or at your local BBQ's Galore store, As they have conversion kits available.
Mar 11, 2011 | Barbeques Galore Turbo Classic 3-Burner...
I am looking for a conversion kit for a BBQ Galore Turbo from NATURAL GAS to Propane
BBQ Best (www.bbqbest.com.au) have natural gas conversion kits so you can convert your bbq from LPG to natural gas. Great site and good advice - Simon the owner was the only guy that could help me out.
Jul 30, 2010 | Barbeques Galore Turbo Classic 3-Burner...
I have a BBQ Galore STS 4-burner grill. How can I
You need to look at the orifices to see if the hole on it is big for Natural Gas and small for LP!
Mar 14, 2010 | Barbeques Galore Turbo STS 4-Burner 169544...
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
Frigidaire GL30LKEC (LP) Grill Logo
147 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
