Question about Samsung Televison & Video
Samsung LE46N87BD vertical line on left hand side of screen of various colours sometimes worse than others but gradually got worse over the last 3 months
JoeO700
  • 80 Answers
SOURCE: Vertical lines on screen when viewing
If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. Joe Weibel
Posted on Feb 12, 2007
  • 18 Answers
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
Posted on May 31, 2008
SOURCE: Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
Posted on Nov 07, 2008
  • 116 Answers
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Posted on Dec 11, 2008
  • 98 Answers
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Posted on Feb 06, 2009
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Vertical lines on samsung ua46b7000wf
Your screen is probably cracked did someone hit the screen with something? Push on the screen lightly next to one of the cracks does it get bigger near your finger? If so you will just have to deal with the lines or replace the TV as it is permanent damage with screen.
Apr 21, 2012 | Samsung 460UX-2 LCD TV
I have a Sony 1410 LCD monitor, when it is powered up the screen displays vertical coloured lines on the left hand side for about 60 ml wide and the remainder of the the screen displays grey and black...
In most cases, this could be due to two factors. One - Your video card is losing life. Two - Your Sony monitor is almost dead. Simple way to trace the root cause is - borrow a monitor from your friend or someone and check. If the borrowed monitor works fine - it is the video card, that should be changed. Else, go for a new monitor.
Lastly, often people forget to check the cables. Sometimes broken pins or bent pin at the connectors could cause the problem too.
Mar 04, 2011 | Sony LMD-1410 14" LCD Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Vertical lines in my laptop screen
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
282 people viewed this question
Jerry Greenberg
Jerry Greenberg
