Question about Hayward Navigator Pool Cleaner
It has good suction but will barely move. I replace the bearing and tblack turbine but is still does the same thing. Any suggestins.
  • 25 Answers
Make sure the pods (the things on the sides) are screwed on Really tight. If they're loose at all, they can't move the cleaner.
www.cpo2go.com
Posted on Dec 03, 2010
How to repair the bearing in the brush motor in s Hoover Steamatic
I believe you are asking about the turbine assembly. It runs off suction and powers the brushes. These commonly seize up due to moisture. They seldom can be fixed although tearing it apart and lubing the bearings can be tried. When we get them in for service they almost always get replaced. They come as an assembly.
1. Remove hood.2. Remove turbine.3. Replace or Repair turbine.4. Reinstall hood.
I'll include a link to a picture of the most common turbine.
Good Luck! The Vac Dr.
http://vacuummedic.com/product.php?id=229
Dec 24, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
Replaced A frame and turbine. Replaced shoes. Everything appears to be fine but moves extremely slow even with good suction. Could the spring on the shoe pods be an issue?? Thanks
Does the turbine spin freely when it is not connected to the suction hose? Sometimes even with a new turbine, they do not spin freely after you have put it back together. This is usually the problem. Also, depending on the type and shape of the pool, too much suction can cause the cleaner to **** to the floor causing drag. Hope this helps.
May 03, 2011 | Hayward Navigator Pool Cleaner
Doesnot climb walls or move around bottom
Some things to look for:
1. Make sure all hoses are connected, to each other and to the skimmer/vacuum port.
2. Make sure you're getting plenty of flow through the hose. Remove the hose from the cleaner an, carefully, check to make sure you're getting good suction. If you don't feel much suction at the hose end, disconnect one section at a time, until you find one with good suction. The last section removed probably has something stuck in it.
3. If you have good suction at the hose end (when checking tip #2) turn cleaner over to determine that nothing is lodged in the opening and preventing the turbine from turning. It doesn't take much to stop the turbine. Twigs, palm leaves or other heavy leaves, small animals, small pebbles, etc.
Another thing to consider is the age of the cleaner. These cleaners need to be "tuned-up" every 12-18 months. I usually replace the pads, pods, turbine, wings, flags and A-frame in a tune-up.
www.cpo2go.com
Nov 28, 2010 | Hayward Navigator Pool Cleaner
My Navigator stopped working---it just sits there. I replaced the foot pads---still nothing!!
if you have enough suction and it still does nothing, even after replacing the shoes, it probably needs a turbine kit with "a" frames. if the bearings are bad on the turbine or a - frames, it won't let it achieve enough range of motion to actually move the unit. I would recommend installing a turbine kit, with a-frames. hope this helps.
Nov 06, 2010 | Hayward Navigator Pool Cleaner
The machine we have has good suction but will not at all move.Tried moving the feet but won't go.Need help on this one
Hayward Navigator has many moving parts that when disturbed can cause movement to slow, be sporadic, or even stop all together. Very often the problem is just a leaf, rock, or other debris causing the impeller not to spin. You can remove the access cover (the small square access plate on the bottom) with one screw and see inside the cleaner much better. other possibilities can be the turbine bearings, a-frame bearings, worn turbine cam, etc. If you don't find a simple solution, bring the cleaner to local pool shop. If they are a reputable company they will Inspect the cleaner for free and replace any parts you buy for free as well. Good Luck!
Sep 20, 2010 | Hayward Navigator Pool Cleaner
Navigator doesnt work
navigators are prone to debris getting stuck in the turbine and causing the unit to stop. Try clearing the turbine and try it again. Depending on the age of the unit, you could also be in need of a turbine kit. There are plastic bearings that hold the turbine and after time they will wear out and cause the unit to not move very well or move in circles. It will look like the pods are moving but since the turbine is not providing the normal range of movement, the unit will not work properly. Take the unit apart and inspect the turbine bearings and "A-Frame" bearings as well. If the bearings are damaged, you'll need to buy a "Turbine kit with a-frames". You should be able to install it yourself.
Mar 29, 2010 | Hayward Navigator Pool Cleaner
Hayward Navigator Moves very slow
check the bearings on the turbine and "a" frames.
also make sure the left and right pods are tightened properly and the pod shoes are in good shape.
Sep 05, 2009 | Hayward Navigator Pool Cleaner
Brushes
This machine has no belts. There is an air driven turbine that propels the brushes. If you look under the little glass window at the left front corner of the machine, there is an intake screen just above the indicator dial. That screen is there to keep debris from entering the turbine and will have to be kept clean. If it is clogged, then the turbine will not function.It is also possible that moisture has entered the turbine and siezed the bearings. If that is the case, the turbine would have to be replaced. Also, because this turbine works off the suction of the motor, if the recovery tank lid is not on correctly, then the suction loss will effect the brushes. Check the lid and make sure it is on right.
Jan 12, 2008 | Hoover F5906-900 Upright Steam Vacuum
Problems with the Hoover Steam vac Heated carpet cleaner
The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hayward Navigator Pool Cleaner Logo
143 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
