Question about Maytag Washing Machines
Where is the "magic filter" on my Maytag la7800
2 Suggested Answers
  • 441 Answers
SOURCE: Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
Posted on Jul 16, 2009
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
Sud error
Remove the lower kickplated and clear the filter out.
Dec 09, 2012 | Maytag MHWE300VW Washer
Can't get the water in the tub & it doesn't spin.
TRY THE LITTLE SWITCH THAT ENGAGES WHEN U SHUT THE LID... MY GE WASHER JUST HAD THE SAME PROBLEM ABOUT A MONTH AGO
Mar 14, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag neptune washing machine. The error code is Lr. I know what that means, but it is 11 years old and am wondering if it is worth it to fix or just replace.
I would say yes, just remember that replacement washing machines are getting really expensive. First, get a couple of quotes on repairing your Maytag washing machine. Ok, what does Lr. mean?
Maybe I could save you some money, that is if you are mechanical inclinded. GB...stewbison.
Sep 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a front loading Maytag Neptune washer. I am constantly gettings the "SUDS" message even when I am hardly putting any soap in. I will also get the "No Drain" message, which used...
This typically happens when you use regular detergent instead of HE detergent, which stresses the pumps. Are you using HE detergent?
Also check for blocked drain hose or clogged water filter.
Apr 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
Constantly stops with code "DC" even with very
Do you want to DIY the fix?
Google this Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine. At that post I discuss what cause is and the fix.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air f
Mar 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washer, model# FAV6800AWW. It is now 5-years old. The countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedly runs for a 30-40 seconds,...
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 02, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Jan 25, 2010 | Maytag PAV2300 Top Load Washer
Cycle switch must be moved manually
what you gona need is a new timer knob.
copy n paste this web address;
http://www.partstore.com/Model/Maytag/Maytag/LAT8106AAE.aspx
"Was this helpful?"
May 08, 2009 | Maytag LAT3600A Top Load Washer
Maytag MAF1200AAW
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Aug 04, 2008 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
