Question about Dryers
Has power but the drum will not turn- belt is not broken- all clothes out
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
My dryer is heating but the drum is not turning, what is the problem?
What you are describing usually means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 while the machine is off put your hand inside the empty drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
http://www.fixya.com/support/t6322596-get
Hope this helps,
Best Regards,
Mark
Jan 21, 2011 | Dryers
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
The Hum most commonly means that the drum belt on your dryer is probably broken
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Hope this helps,
Best Regards,
Mark
Jan 19, 2011 | Whirlpool Dryers
Dryer can't turn on. Start button just buzzes.
replace the "Broken-Belt" switch by the drum motor,when the belt breaks it shuts off the heating element so as not to burn the clothes because the drum can't turn to produce air flow to dry the clothes as they tumble,when you replace the belt it will make the switch close the circuit again and it will start
Dec 26, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore electric dryer won't start
it is possible that your belt is broken open the door manually turn the drum by hand if it turns frely then the belt is broken if not it could be your door switch that has failes but normally for this problem its a broken belt
Mar 15, 2009 | Dryers
Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Nov 25, 2008 | GE Dryers
My electric clothes dryer will not turn on, however the heating element gets hot. What is my problem
This can be caused by two things one a broken belt or 2 a short in the switch on the motor the motor must be running to send power to the heating element. ..Here is the question for you
1.Is the drum turning
2. if yes check the switch at the motor
3. if no then your belt is most likely broken
Aug 05, 2008 | Dryers
My lint filter assembly is broken. I was drying a small load of clothes and the lint filter got tangled with clothes and came out into the drum. The dryer was stopped when I found this situation. ...
The drum should turn either direction. Part of the filter must be catching in the belt at the drum or motor when turning clockwise. CCW would push it out away from the belt so no pinching.
May 29, 2008 | Amana Dryers
Dryers Logo
32 people viewed this question
Top Dryers Experts
