Question about New World 55WLg Gas Kitchen Range
New World 55TWLG - door problem
I have a New World 55TWLG fitted on my narrowboat. This is a result of a safety inspection as my old cooker didn't meet standards. This new cooker is lovely apart from the fact that it takes forever to cook anything in the oven.
I think this may be due to the fact that it does not have the correct fittings on the oven door and possibly the grill door. It does not seem to make a seal round the door.
Can you tell me if there should be an inner and outer glass to the doors?
Thanks in advance
SOURCE: New World E70DOA - Oven/Grill Temperature
Steve, I have a PDF of the manual. send me an email to david.stevens@vibanalysis.co.uk and I will reply with document attached.. We recentley moved house and were in the same situation. We contacted Newworld who sent us a paper copy which I have scanned to PDF.
Dave
Posted on May 04, 2008
SOURCE: New World Twinline 3001
Brute force and total ignorance seemed to work!!
Posted on Jul 15, 2008
SOURCE: Oven stopped working
replase the oven ignitor it's located nest to the oven burner.
Posted on Dec 11, 2008
barkencoa
  • 3463 Answers
SOURCE: New World G90M
Normally they are held on with metal clips at each corner, just pull the seal back and unhook the clips to remove the seal..
Re fit by hooking the clips into the holes in the front of the oven, you will probably have to stretch the seal to get it to fit with it being new.
Plz rate this solution.
Thanks.
Posted on Dec 19, 2008
SOURCE: new world gas cooker (apex hl 500)
the battery compartment is located right at the bottom of the cooker on the front, slightly to the left. It's a little compartment that houses a aa battery. it's unclips on the right hand side. hope this helps
Posted on Oct 15, 2009
New world cooker classic 100DF.Glass door outside glass shattered. Looking for new one.
Fixya is unable to suggest sources for New World cooker parts.
Apr 12, 2018 | New World Ovens
Can I fit a plug to new world vision 50 ecwlm cooker instead of electric box? Tried to find out if over 2.9kw but 2nd hand and no manual details
I have heard of people doing that and getting away with it - such is the capacity of the modern domestic ring circuit. Certainly no one should be doing it and no one with electrical knowledge would condone or recommend such a thing as if you didn't get away with it, it could burn your house down without blowing a fuse or tripping any safety devices.
The cables carrying the current to the sockets and light fittings traverse many flammable things between the power outlet and the electricity meter...
In an emergency you could fit a plug and use the cooker but never, ever more than one boiling ring and one simmer ring OR the grill OR perhaps even the oven if it is a conventional oven.
If you do decide to take the chance I advise you most strongly never to trust anyone else to operate the cooker and never to leave it unattended...
A large boiling ring is typically 1500/2000 watts and a small simmering ring is typically 800/1000 watts. I can't tell you what the consumption of the other equipment might be but it should be easy to discover as the manufacturer might have a downloadable manual on the website or you could try googling replacement heating elements.
You should have a cooker outlet installed as soon as possible.
Oct 01, 2016 | New World Ovens
I need to replace a grill element in a new world dual fuel cooker but can't see how to gain access to the back of the grill
Google search below for should work - as I don't know which one you have you will have to sort through results to find answer that works.,
Google
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 21, 2016 | New World Spirit 100 DF Dual Fuel...
Can you please tell me how to change the rear wheel bearings on a 1999 Vauxhall corsa van. The make and model is not correct it didnt have Vauxhall to choose from. Thank you Rob
yes sorry but you know the americans ,they dont do geography and they beleave in flat earth theory ,lose sight of land and the world stops ,yes easy job they are taper bearings on vehicle of this age and easy to change ,hardest part is knocking the bearing paths out ,when i service vehicles and i always take the back drums off to clean and inspect and adjust the auto brake adjuster i always put some engine oil in the dust cap before i refit to keep the grease soft ,anyway dont you know this is a opel not a vauhall -GB doesnt exist anymore across the channel but its a third world religious ethnic state of mohamed .
Jan 03, 2011 | Volkswagen Corrado Cars & Trucks
Oven door open or shut when using grill?
Leave the door open in the broiler position, about 4 inches.
Jan 06, 2010 | Ovens
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Sep 15, 2009 | New World G70m Gas Double Oven
How to fit main oven door on stove 1200 Range cooker 100 DFA
Open the door part way, then grasp the door on either side and lift up and out to release the hinge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 13, 2009 | Kitchen Ranges
New world gas cooker (apex hl 500)
Jan 31, 2009 | New World 50HLG Gas Kitchen Range
New World Classic 100 cooker
The closk and ignition is no longer working, how do I solve this?
Aug 27, 2008 | New World Ellingwood 100 (Gas) Kitchen...
New World 55WLg Gas Kitchen Range Logo
128 people viewed this question
Top New World Kitchen Ranges Experts
ashburton
Ismael Rodriguez...
Paul Carew
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
