Question about Sony Playstation 3 (PS3) Console
My Ps3 is suddenly switching itself off now after about 2mins of gameplay, this is happenijng with every game i load. After it switches off, the red light continues to flash. Can anyone help please?
    President:
  • 1,139 Answers
I am sorry to say that this is what is known as the Yellow Light of Death (YLOD). This indicates a general hardware failure normally due to overheating. When these PS3's were produced Sony decided to use lead free solder. The problem with lead free solder is that it is not as flexible as leaded solder but it is cheaper and more environmentally friendly. When the console gets hot and cools down hairline cracks appear within these solder joints and a good electrical contact cannot be made. This then causes the console to fail. It could be on a number of different components including the CPU, GPU or memory. There is a temporary cure that may or may not work but ultimately the console will need to be repaired professionally or replaced. If it is out of warranty Sony will not replace it but will offer a refurbished unit for around £130. If you look on Youtube for Yellow light of death fix there is a way that you can re-heat the solder joints using a heat gun but if you are not confident taking apart electrical items then this really may not be something you want to try.
I am sorry I cant give you any better news but unfortunately it is a very common problem with the PS3
Hope this helps, thanks for using FixYa
Posted on Nov 07, 2010
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Sometimes my ps3 freezes while loading also during gameplay and just in gameplay there are color streaks and glitches occur
This sounds like a problem with the HDD. If you have any save files you wish to back up, use the Backup Utility under the settings menu. Once you've done that, Format the PS3. If you are still experiencing problems you will need to contact Sony. Their number is 1-800-345-7669.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
When i turn on my playstion 3 console it switches back off and shows me a flashing red light and the if i keep trying for about 1 hour it turns on but then when i turn on the game to play it switches...
there are series of problem in ps3 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot Click Here
Dec 06, 2010 | Sony Playstation 3 (PS3) Console
My fan is on constantly 2mins after switching on
unfortunately the PS3 fan is a bit noisy, unless you have the slim version. I wouldn't say it is a problem, mine does the same since i bought it.
Jul 31, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 power issue
Your system has overheated. If it doesn't get on at all anymore, you should get it fixed in the place you bought it from. That happened to me.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
I switch my ps3 on and start to play a game and then sfter about 10 mins it switces itself off and a red light flashes, then the same happens again after i switch it on. could it be overheated?
sure, it can. try cleaning your coolers : turn the on off switch behind the console OFF, then hold the eject button and , HOLDING THE EJECT BUTTON,switch the on off key ON (behind the system). it will clean your coolers.
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
I cannot play games
if it sound like 3 beeps then it goes off that means that the ps3 freezes while opening the game so it switch off itself
Aug 25, 2008 | Sony Playstation 3 (PS3) Console
Ps3 controller
everytime you play the Ps3 and you try to play a game it loads and you have to press the PS3 button again.
click the Thank me Button XD
I helped all i can
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
