Question about Dell Inspiron 531s Desktop Computer
CD Drive not working - doesn't open or close on its own. I use an open paper clip to to this. Now doesn't recognize disc when inside and does not play. I can't find it on the file list, either.
  • 1,179 Answers
You can consider this puppy broke, however it doesn't hurt to try some-thing to get it going again. Open your computer case and write down the make and model number down of your CD drive exactly. Type this into google plus firmware. Hence this will search for the latest firmware for you CD drive. Download the file and execute the install. Follow the instructions. This will install a piece of code to the memory chip of that CD drive. Must be exactly the firmware for that particular drive or it will be forever lost.
The other alternative is to purchase a replacement drive, it's a little easier and less complicated.
All the best, Thumbs up!!!
damnor01
Posted on Nov 07, 2010
Testimonial: "Thanks for the quick and practical answers. Much appreciated. "
A 2year old put a train ticket inside the dvd/cd drive and now its stuck
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Jul 11, 2012 | Dell XPS M1330 Notebook
I have a hp laptop cd stuck inside how do you get it out
CD Drive Tray problems
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
May 29, 2012 | HP Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
How to eject a cd in a dell XPS m1330 when the hardis has crashed and the disk inside isn't a operatindg system disc
Straighten a paper clip and insert it into a tiny hole below the CD drive tray. Push the paper clip gently into this hole and the CD tray will pop out slightly. Pull the tray out to the fully opened position so you can remove the disc.
Dec 28, 2011 | Dell Computers & Internet
Computer won't start up - says file missing or corrupt: \windows\system 32\config\system. cannot open cd=rom to use original set-up CD
That folder contains all of your Windows files, so your operating system is no good anymore. So you have to reinstall Windows. It sounds like you have the disc so we just need to get that drive open. To get your CD drive open, you have to use the override system. On most CD drives, there's a little hole on the front. Sometimes it's hard to see. What you need to do it get a paper clip and straighten it out. Then stick the paper clip in that tiny hole. Keep going in until you feel a little catch, then keep pressing. This will mechanically open you CD drive. Just put the disc in and close it up again. Hopefully your reinstallation of Windows will work out. Best of luck!
Apr 12, 2011 | Microsoft Windows XP Professional
Acer Aspire 5535 will not recognize disc inside, so I cannot eject it. How can I eject it now?
Hi, the disc drive has an emergency eject hole on the front. With the laptop switched off, insert a paper-clip (or similar thin object) into the hole until the cd pops out. This is number 4 in the picture below:
Apr 11, 2011 | Acer Computers & Internet
I placed a cd on my cd holder and the cd fell off inside the processor. How can I get the cd out?
Use paper clip and stick it through a small just outside the cd drive (should be next to the cd button where you press to eject the cd out). Stick paper clip through this small hole until the cd door open and gently take cd disc out. Good luck
Apr 09, 2011 | Computers & Internet
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
I have a dimensionsC521 that has swallowed my cd disc. It is an awkward cd slide since the cd does not stand upright and so I usually tilt the tower over so it doesn't slip out. Now it slipped out and the...
I suspect this is more a mechanical problem than a power or software problem
I suggest powering down your PC,
Laying it down so the CD draw is flat,
Fashioning yourself a home made cd draw ejector device (otherwise known as a straightened paper clip),
Pressing the paper clip quite firmly into the tiny hole next to the CD Draw (it should unlock and open slightly)
Carefully and gently pulling the CD Draw out just enough to see inside and find out where the disc has got to
Physically maneouvering your whole PC to get the disc back onto the tray where it should be
Then you can either manually pull the CD Draw out and remove the disc or start the PC while it's laid down flat and see if the CD Drive auto closes and begins to spin now the disc is properly seated
If your PC doesn't have the tiny hole on the front of the Drive or if the CD Disc cannot be seen at all or cannot be persuaded back onto the tray then it's time to start opening up your PC case and removing the CD Drive for more attention
- NOTE if your PC is still under warranty Opening the Case may invalidate that warranty, check this before you proceed -
Treat Everything Gently and Good Luck!
Sep 16, 2009 | Dell Dimension C521 PC Desktop
CD drine issue
To manually open the CD Drive, straighten a paper clip and insert it into a tiny hole in the front of your CD drive and push the paper clip gently into the drive and the tray should then pop open.
Open and close this several times, then insert a disc into the drive and see if it will read the disc.
If not the drive is dead and needs to be replaced.
Nov 18, 2008 | Acer (KV.16X04.007) DVD Drive
Dell Inspiron 531s Desktop Computer   Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
