Question about Frigidaire PLEB27T9DC Electric Double Oven
Frigidaire Electric Range ES200/300
Hi there! My Stove top is working fine, but my oven won't come on. I think it may have happened during a storm. The knobs work, but the display won't let me set the clock or my oven. Is there a fuse or something maybe that can be replaced?
  • 5 more comments
  • sfclilo1 Nov 30, 2008
    I have a Frigidaire ES200/300 electric range that displays F1 and beeps constantly. Do I need to call a service tech.
  • Anonymous Dec 23, 2008
    the top of stove is working but the oven will not come on
  • Anonymous Mar 13, 2014
    I have a frigidaire oven that is showing a pf error however the top stove works but not the oven. It is an electrical stove.
    i have a frigidaire electric stove that is showing a pf error. The stove works but not the oven
  • Anonymous Mar 23, 2014
    the heating element does not get red Thermostat or heating element? do they still make them?
    oven not working
  • 66 Answers
There is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
Posted on Jun 16, 2008
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a self-cleaning older Frigidaire oven RE36BNL*2 and have had several power interuptions. I went to use the oven and the timer and oven controls won't work. There is an OFF displayed and it...
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Sep 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
The oven does not work but the stove top does
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
Feb 15, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery stove, oven not working,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Dec 28, 2017 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire Gallery ES340 electric range, burners will not turn on
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Oven wont work
If the sensor were bad, the unit would throw a fault code. On the back of the range, near the top, there should be a tech sheet for you to use to troubleshoot the range. It sounds like a thermal sensor may have opened up. Consult that tech sheet, it should point you in the right direction.
Dec 12, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire PLEB27T9DC Electric Double Oven Logo
2,278 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
