Question about Homelite Factory Reconditioned 26cc Gas-Powered MightyLite Hedge Trimmer
No spark. I changed plug and still no spark - Homelite Factory Reconditioned 26cc Gas-Powered MightyLite Hedge Trimmer
  • 718 Answers
First check to see that the (on-off) switch is working properly, if switch checks out, you need to replace coil.
Posted on Nov 07, 2010
How often should I change spark plugs on a 2010 Mini Cooper clubman?
There isnt really a mention on how often you should change your spark plugs some manufacturers say certain plugs are good for upto a certain mileage
Check with your spark plug manufacturers recommendation on spark plug changing intervals
https://www.ngksparkplugs.com/about-ngk/faqs/spark-plug-faqs/how-often-should-i-replace-my-spark-plugs
Sep 24, 2017 | Mini Cars & Trucks
Sonata spark plugs
here you go
Hyundai Sonata Spark Plug - AutoZone
www.autozone.com/external-engine/spark-plug/hyundai/sonata
  1. Cached
On modified performance engines, it's generally best to use a colder heat range plug. Old spark plugs for Hyundai Sonata often produce a rough and jittery ...
Hyundai Sonata Spark Plugs - Spark Plug - Denso NGK Bosch - 2011 ...
www.partsgeek.com > Spark Plugs > Hyundai Spark Plugs > Sonata Parts
  1. Cached
  2. Similar
Rating: 5 - ‎25 reviews Spark Plugs produce the spark for fuel combustion in your vehicle's engine.
How to Change Spark Plugs on Hyundai Sonata - 4 cylinder - YouTube
2q==? 5:08 https://www.youtube.com/watch?v=Dr8HOJv7HzM
  1. Similar
Apr 13, 2014 - Uploaded by HappenToLife This is a how to video for changing spark plugs on a Hyundai Sonata. The car in the video is a 2007 model ...
Hyundai Sonata Spark Plug - Auto Parts Warehouse
www.autopartswarehouse.com > Hyundai > Sonata > Spark Plug
  1. Cached
  2. Similar
BOSCH PLATINUM+4 SPARK PLUGS. Engineered with advanced surface air gap set-up for prolonged, more powerful spark; Features platinum center ... sonata spark plugs Google Search
Apr 14, 2017 | Cars & Trucks
Change spark plugs on a 2004 buick lesaber
Why you want change spark plugs wire .THIS IS LAST THING TO CHANGE.Change spark plugs I agree.
Apr 01, 2013 | 2004 Buick LeSabre Custom
Engine missing wont fire properly, i think its the spark plugs how do i change them ?
CHANGE SPARK PLUGS.YOU NEED SPARK PLUG 3/8 SOCKET.YOU NEED SHORT AND LONG 3/8 EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER AND A SPARK PLUG GAUGE SET THE SPARK PLUG GAP.NOW CHANGE 1 SPARK PLUG AT A TIME SO YOU MIX THEM UP GET FIRING ORDER MIX UP CAR BACK FIRE WONT CRANK.ALSO CHANGE PLUG WIRES ALSO.
Nov 10, 2010 | 1994 Honda Civic
How do you change the spark plugs?
To change the spark plug on chain saw or any small engine >>
> pull off the spark plug wire
> use a socket wrench (like mechanics use on cars)
> select right size socket (buy at hardware store
> the hardware store might remove the spark plug for you
> rotate spark plug counterclockwise to remove
> identify correct spark plug (buy at hardware store/ home center in lawn and garden section)
> Install new spark plug
> push spark plug wire back onto spark plug
Oct 10, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
How to change plugs on honda odyssey 2005
you will need
8mm
10mm
5/8 spark plug socket
3/8 ratchet
3/8 extension (it could be 4in and longer)
and spark plugs factory plugs are pregap iridium
spark plug torque is 13.0 lb.ft
coil torque 8.7 lbf.ft
spark plug part # NGK 1zfr5k-11
# DENSO pkj16dr-m11
and spark plug anti seize on spark plug thread
what you need to do is remove the plastic cover 8mm socket or 10mm sockets
now remove the spark plug covers and remove the spark plug coils too 10mm head bolt you will need a 5/8 spark plug socket and a 3/8 ratchet and a 3/8's extension too
you need OEM spark plugs they work the best
hope this will help
May 22, 2010 | 2005 Honda Odyssey
I would like to know how to change the spark
FIRST OF ALL YOU HAVE CHANGE SPARK PLUGS WHEN ENGINE IS COOL.IF YOU CHANGE THEM WHILE ENGINE IS HOT YOU COULD DAMAGE THE ALUMINUM HEADS OR CAUSE DISTORTION.TO CHANGE SPARK PLUGS YOU NEED A SPARK PLUG SOCKET.A TORQUE WRENCH.ITS NOT MANDATORY.BUT IT WILL KEEP YOU FROM OVER TIGHTEN SPARK PLUGS.YOU NEED A 3/8 RATCHET AND EXTENSION.YOU ALSO NEED A SPARK PLUG GAP GAUGE.AND SPARK PLUG BOOT PULLER.YOU ALSO NEED SOME ANTI SEIZE COMPOUND.TO PREVENT DAMAGE THREADS WHEN INSTALLING THE SPARK PLUGS.
Oct 13, 2009 | 1999 Ford Expedition
Change spark plugs on 2007 Toyota Camry
In servicing the spark plug . If the owner will be the one to change the spark plug then. the owner should locate the spark plugs . then prepare the equipments that is going to be used to change spark plug .First disconnect the spark plug cable to the spark pug . Then use the equipment to take the spark plug off to the engine. The spark plug should be twisted counter clock wise using the equipment to remove the spark plug.Then replace the spark plug.In returning the spark plug ,using the equipment you have to twist the spark plug clock wise . Then set the distributor shaft turn it according to the proper firing order that will be set to the spark plug if it is 1,3,4,2. Then the distributor shaft mark will be on 1.If 2,3,4,1 then the distributor shaft mark will be on 2. Then connect the spark plug cable , after connecting the owner have to test start the car so that to if it back fires .If it back fires then the owner have to repeat again the setting of the firing order of the spark plug until it will not back fires.If the owner don't have time to do the job in servicing or changing spark plug then the owner have to go to a car mechanic and let them change the spark plug.
Sep 26, 2009 | 2007 Toyota Camry
Change sparks plugs on 06 hyundai sonata v6
You didn't specify whether you have the (4) cylinder or the (6) cylinder engine..... I have a 2004 Hyundai Sonata 2.4L 4 cylinder and I just changed the spark plugs in it. I believe that the 2005 2.4L engine is the same. To locate and change the (4) spark plugs on a 2004 Hyundai 2.4L 4 cylinder engine: Remove the (4) 12mm bolts from the decorative plastic engine cover. Remove plastic cover from engine and place it off to the side out of your way. Standing in front of the car, the (4) spark plugs are located laterally (left to right) in the recessed area underneath where the plastic engine cover was removed. Note: This engine has (2) coils....They are located above spark plugs number (2) and (3) from left to right. Starting with the fist spark plug on the left: Remove the spark plug cable by pulling straight up on the insulated connector. Using a spark plug socket, remove the old spark plug and install a new one in it's place. To access the second spark plug from the left, remove the electrical connector and the spark plug cable wire from coil number (1) and then remove the (2) 12mm bolts that secure the coil to the engine. Spark plug number (2) is located directly under the coil. Lift the coil straight up removing the insulated connector from spark plug number (2). Using a spark plug socket, remove old spark and install a new one in it's place. Repeat same procedures for spark plugs number (3) and (4). Note: If you have the (6) cylinder engine, the front (3) sparks pluge are readilly accessible but in order to access the (3) rear spark plugs, you will have to remove the intake manifold
Jul 08, 2009 | 2006 Hyundai Sonata
Changing Spark plugs 2005 Colorado
what is involved in changing spark plugs and which type is recommended?
Oct 31, 2008 | 2005 Chevrolet Colorado
Homelite Factory Reconditioned  26cc Gas-Powered MightyLite Hedge Trimmer  Logo
587 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
