Question about NetGear WGR614 Router
Can't connect to internet- suddenly after working for years, my router won't connect to web. I can connect with a direct connection from modem to computer
  • NetGear Master
  • 27,725 Answers
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
From the center screen, select your encryption type from under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Posted on Nov 07, 2010
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
Hello. I have a Dlink dir 600 router and it worked without problems for about a year (usually there were 2-3 laptops wirellesly connected to it). Then suddenly I couldn?t connect to the internet anymore....
Make sure all the wires are connected properly. 1.-Unplug your modem and router from the power supply. Wait 1 minute. 2.-Plug your modem back to the power and wait for all the lights to stop flashing. 3.-Plug your router back to the power and wait for the lights to stop flashing
Follow these steps and your internet should be working again!
Jan 13, 2011 | D-Link DIR-600 Router
When I plug internet cable into router it will not recognize internet access. I have had a running system for 4 years and no problems. Now all of a sudden it will not work.Internet works when directly...
plug internet cable into router and access it through its ip add 192.168.1.1 with username admin and password admin and see manual setting. After access inside the router u can manually type ip add , dns adds of your local ISP then run dhcp and finally restart your router ........hope u will connect internet very soon
Apr 16, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot connect thru linksys router to internet. I can connect with direct cable but when connected to linksys does not connect.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 17, 2010 | Linksys Wireless-G WRT54G Router
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My wirless devices can find my router but fail to connect to the internet.
Can the devices connect to the web when plugged directly into the modem? if not, contact internet provider. If yes, reboot modem, make sure it is connected to the wan/internet port (not one of the 4 lan ports) and reboot the router. If no good then replace ethernet cable between modem and router. If still no good, press and hold reset button on router to put it back to factory settings. If still no good and router is less than 1 year old, contact the manufacturer for a warranty replacement. If out of warranty, try another router.
Aug 08, 2009 | D-Link DIR-615 Wireless Router
Lost DHCP connection. I changed nothing on my config
You may want to press and hold (using a pen or a paper clip) the reset button of the router for 30 seconds and then unplug the power of the router. Turn off the modem, wait for 10 seconds, turn on the modem, and then the router, and make sure that the modem is connected to the internet port of the router and PC to the ethernet port (1, 2, 3 or 4). See if the router will obtain an IP address from the modem. If not, download here http://www.linksysbycisco.com/US/en/support/WRT54G2/download the latest firmware for the router.
Ensure that you download the correct version for the router.
Jul 19, 2009 | Linksys Wireless-G WRT54GS Router...
Wrt54g V8 Suddenly stopped working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | Linksys Wireless-G WRT54G Router
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
NetGear WGR614 Router Logo
93 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
