Question about Kwikset 907 907-L03 Lifetime Polished Brass Powerbolt Keypad Electronic Dea
My front door Kwikset keyless handle came apart and now I have several parts, gear, and springs.. How do I put them back together?
Hi, did you ever come up with a solution? The same thing just happened to me and I can find no schematics on the internet that tell me how to put it back together.
Posted on Sep 21, 2011
  • RJBush Dec 17, 2012
    Same problem here. Any ideas?
Kwickset door handle fell apart on my front door help
Kwikset locks are inexpensive because they do not have replaceable parts. Buy a new one.
By the time the lock breaks, it's probably time to get different keys, but if you have so many keys in the hands of people you cannot contact, or you have more than three other locks keyed alike, and you must have the new lock work with the same keys as before, the place where you buy new locks probably has someone who can rekey the new lock to your old keys. Kwikset also sells locks that you can rekey to other Kwikset keys yourself. They are more expensive than other locks of the same type, but could save money long term, especially if you find a need to rekey your locks a lot (lots of visitors, part-time tenants or roommates, your kids lose their keys a lot, etc.)
Sep 07, 2013 | Kwikset Professional Door Lock...
I replaced the seats and springs in my delta single handle faucet put it all back together and now I have nothing. I took it apart again - actually several times and put it back together with the same
messy ,, but while u had it apart did u turn on the water to see if water would come out at all... we flushed our line and that cleared up the problem.
Jan 19, 2013 | Delta Plumbing
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
Gear spinning several times when locking the door.
Mechanical problems internal to the lock are covered by lifetime warranty. Contact Kwikset.
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Sep 25, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Could you send instructions for thumb door handle ours fell apart and we don't know where the pieces fit....thank you
Sure, let me give you a link to the installation instructions for the Kwikset Lido(keyed lock):
http://s7d5.scene7.com/is/content/BDHHI/44593-01
If this is not what you had in mind, go to this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Levers_Lido
and select the model most like yours. Clicking on the picture will bring up installation and warranty links, etc.
Please note that if I haven't been able to help you, then I urge you to contact Kwikset Customer Support:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Jun 17, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Our kwickset entrance handle and deadbolt including our french doors handles all on outside are an oil-rubbed finish. The protective finish on each handles is peeling off. We purchased this home brand...
Here is a link to the Kwikset warranty information:
which states in part:
"If a mechanical or finish defect occurs, please call 1-800-327-LOCK (5625) in the U.S. and Canada or return it to Kwikset Corporation, Consumer Services, 19701 Da Vinci, Lake Forest, CA 92610. For customers outside of the U.S. and Canada, claims under this warranty must be made only to either the place of purchase or to the listed importer."
Apr 20, 2011 | Kwikset Locks & Locksmithing
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
My door handle came apart and now I have the pieces and don't know how to put them back together. Kwikset, chelsea door handle.
I assume the latch mechanism is still intact... the piece on the edge of the door that locks inside the strike plate when the door is shut -- if that's the case the only thing left to do is align the two knobs, one on iether side of the door, making sure the shaft goes thru the latch mechanism properly (it only fits thru one way) and then sandwich it tightly to the door and tighten it together with a phillips head screwdriver... some kwikset locks require you to turn one of the knobs to get the bolt heads to seat properly.
I'm not familiar with the chelsea model but they are all very similar... if you have more than the 2 knobs with a long shaft on one then chances are the solution above does not apply... you probably will have a knob with shaft and then a flat plate with holes, a finished plate and a plain knob... in this case align the knob and shaft thru the latch mechanism, place the plate with holes on the other side of the door and twist it slightly so the bolt heads lock in and tighten the bolts to the plate... now snap the finished plate over that and push the knob over the exposed shaft that remains... you'll need a flat head screw driver to lock the knob on where a small spring loaded piece fits into a cutout on the handle...
that's about the best I can explain it.
Mar 30, 2009 | Hardware & Accessories
Fixing a door
I took other hinge apart.
Removed front glass by removing handle -bar.
Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly.
Removed control panel assembly by taking out 5 screws.
Started with one side hinge first.
Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside.
With the same screwdriver engaged a little hinge to the notch of larger arm..
Did the same thing for other hinge.
Put the upper screws back,
Tightened bottom screws back.
Put the front glass and handle-bar back.
Put control panel assembly back.
Now it is ready to go.
Door is Fixed.
Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
May 09, 2008 | Cadco OV-250 Electric Single Oven
Kwikset 907  907-L03 Lifetime Polished Brass Powerbolt Keypad Electronic Dea Logo
253 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
Steve Masymas
Level 1 Expert
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
