Question about Water Heaters
How to remove pcb on a baxi solo 2 40 pf. - Water Heaters
3 Suggested Answers
  • 8404 Answers
SOURCE: hi, what is the maximum rear flue allowed on baxi
This is a very difficult question to answer since Local Codes are not standard. I'm not even sure if we are in the same country ...
I think you really want to know what is the minimum distance your flue can be to combustible material ... not the maximum .. the maximum would be the edge of your property, really, if you think about it.
May I suggest you contact your govenering body (the building inspector (or what ever he or she is called in your area)) and make this inquiry.
Thank you for posting on FixYa.com
Positive comments welcome
a
Posted on Nov 02, 2009
  • 150 Answers
SOURCE: Boiler not working
When the fan stops working it also stops the boiler. Safety.
Check that the fan is turning and blowing air out. You can hear it turning at the top of the boiler and at the vent pipe exit.
With the electrics off, remove front cover and test the fan by moving the blades by hand. Any element of stiffness or jerking or if the fan does not turn freely - replace. These have an induction motor - no repair
Check the electrical contact wires to fan are ok. If the fan is ok check also the 2 plastic tubes to & from the air pressure unit [usually close to one side of the fan] are intact [no splits or holes and will maintain pressure and vacuum] and fully connected to their metal terminals.
Next is to examine the pcb (the electronic board behind the switches) Look for any block connections loose and any obvious signs of black marks on the board. If the latter, replace
Posted on Mar 17, 2010
Testimonial: "Thank you very much rod, cheers"
Have a Baxi solo boiler 340PF, have hot water but no heating, pilot light will not stay on. how do I fix it so I get heating please?
it might be the thermal coupler....it is a piece of wire that goes from the pilot to the thermostat. very inexpensive. .I am a 50 yr old woman, and I changed mine on my furnace twice..Home Depot or equivalent should be able to help. Google "thermal coupler"
Jan 22, 2013 | Water Heaters
How do i fix problem E119 on a baxi duotec combi 24HE - boiler won't light because of lack of pressure but I have no manual to assist me as the instructions on the boiler says.
http://www.bhl.co.uk/uploads/article1477/Baxi%20Duotec%20HE%20Combi%20Boilers%2024,28,33,40%20Installation%20Instructions.pdf top the pressure by the filling loop
Jan 23, 2011 | Water Heaters
Boiler not working
Mar 17, 2010 | Water Heaters
Hi, what is the maximum rear flue allowed on baxi solo 2 pf60, thanks
a
Nov 02, 2009 | Water Heaters
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Overheating
you could have a flow problem due to sludge or scale in the boiler, it could be a pump problem as it may not be circulating enough water around the system. or it could be a faulty thermostat if it is not cutting out soon enough.
1st try turning the boiler stat down to its minimum, if it still over heats then it is probably the stat.
if you have a switch on your pump to increase the speed make sure it is on setting 3. if the pump is old then it may be time for a replacement.
Mar 01, 2009 | Water Heaters
Manual for Baxi Boiler
any merchant will get one mailed out to you
Jan 24, 2009 | Water Heaters
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Water Heaters Logo
132 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
