Question about Kenmore HE3T Washer
My kenmore elite he3t model #110 42922 200) has power but wont start-checked belt,plug in and fuse
4 Suggested Answers
SOURCE: Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Posted on Oct 02, 2008
  • 10 Answers
SOURCE: Kenmore Elite HE3T model 110 44932 200
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Posted on Jul 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite frontload he3t dispaly is on but machine wont start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@!@!
Posted on Sep 30, 2010
Kenmore elite he3t front load washer has no power. Replaced ccu, worked for a few minutes then stopped. Unable to power up
I would guess you have a short in the machine somewhere and likely have fried the new CCU also. If you want to and have the ability, you can track down the short and fix that. Then you will probably have to purchase another CCU before it will run. Wish I had better news. Good luck.
Jun 22, 2016 | Kenmore Washing Machines
Door wont lock, cycle doesn't start
interlock could be knackerd...................cheers
Jan 22, 2014 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Door wont lock cycle wont start
Try unplugging the machine for 5 minutes then plug it back in to reboot it.
Jan 22, 2014 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
How do you reset the computer on kenmore elite he3t steamer
UNPLUG FROM WALL SOCKET FOR 5 MINUETS PLUG BACK IN TRY AGAIN IF YOUR DRYER IS HARD WIRED DO THE SAME AT THE FUSE OR BREAKER
Oct 30, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
My kenmore elite he3t washer and dryer are not getting any power. The electrical outlet they were plugged into blew. I have plugged them into another outlet and they do not come on. Is there an internal...
yes there inside of the machineunplug machine from wall take cover off follow power cord goinging into washer should be a button to push in there
Dec 05, 2010 | Washing Machines
Washer makes knocking noise while in spin cycle. Shock absorbers have been replaced and are good and machine is level. Kenmore Elite H E 3T Model #44932
Check your front and rear counter-weights. They are made of concrete and start to chip away. More so the rear than the front. When you open it up look on the base and see if you have chips or chunks of concrete. I had that problem as well - also make sure you spray lube inside,check your "Spider" wheel, and belt.
Jul 12, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite HE3t broken belt, maybe?
Chances are due to the description of your problem, especially the noise you describe, is most likely a serious issue. If it sounded like a jet engine when going into spin, the rear bearing may be shot which breaks the belt. This happens over time from using too much sudsy detergent and it drys out the seal and binds up the basket shaft and pow, it blows out the belt. Forget about fixing it, its a gonner! (Sorry) If you replace it with another High efficency machine, READ THE DIRECTIONS AND FOLLOW THEM TO THE LETTER. Especially the use of He detergents only!!
Mar 17, 2010 | Kenmore Elite 45986 Front Load Washer
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Kenmore HE3T Washer Logo
440 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
