Question about Acer TravelMate 2300 Notebook
Wireless connection up until 2 weeks ago, I was able to access the Internet through my d-link. Two weeks ago, I could no longer see any wireless networks. I have talked at length with both Shaw (modem) and dlink (router) tech supports. After hours of trouble shooting, it would appear that the problem is with the computer - Acer travelmate 4220, thoughts??
  • 130 Answers
That unit has a driver problem, for the usb or ethernet, you might be able to re-install the specific drivers on their web site, and retry it there, unless the wireless in pci based and the you have a driver problem there, if you can use the ethernet connection then it's usb or pcmci, try that, if that doesn't work you need a tech to look at it.
hope this helps you out, let me know
Posted on Jun 15, 2008
Wireless internet limited connectivity
The first thing to do is reset the router. There is a button on the router that you press with a paper clip.You will then have to access the router with your browser and a cat5 cable connection to change all the settings that you might need to change for security. DHCP should be enabled and there should not be an issue with the number of concurrent connections.
Feb 28, 2014 | Computers & Internet
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Gateway purchased new 3/2010 has been connecting flawlessly to wireless internet until a few weeks ago. Solution had been to click on Open Network and Sharing Center, click on Troubleshoot problems, click...
Are you connecting to your own wireless router? If yes, have you changed anything in its configuration, or inadvertently reset it? If you're connecting to someone else's router (neighbor, etc.) it could be that they have locked you out. Does the wireless network show as secured? This sounds more like a security issue than hardware or driver.
Jan 06, 2011 | Gateway Computers & Internet
Can't establish connection by cable
Assuming you would have checked your LAN port. Try using a USB LAN port device and see if it picks up. Else you can test connecting the modem via Ethernet cable to another machine. Does it work,? If it does then its your machine.
Apr 11, 2010 | D-Link DIR-300 Wireless Router
Wireless no longer accesses router
OK try this go to that PC, go START>>RUN>>service.msc (enter) Now when services window comes up, scroll down to DHCP, set to OFF & Disable, reboot, now try again. Sometimes just a Turn it ALL OFF, and ON again and most often it will sort itself out., IF it was working OK prior. You could always run the "Connect to internet Wizard" again, and do that. Also go into router and ensure that DHCP, is set to ON in the Router. Sometimes, a simple re-setup will get it all working again too.
Apr 01, 2010 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
Bought a NetGear WPN111 RangeMax Wireless USB 2.0 Adapter a few months ago. It was working fine up until a few days ago. It started dropping my internet connection, and now it won't even detect any...
Hi
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers http://kb.netgear.com/app/answers/detail/a_id/12520
If the problem still persists
try changing the wireless settings on the wireless router.
Nov 12, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Wireless network access: 1 laptop fine, other not so much
Check the wireless card on the PC first. Go to "My Computer" then "Device Manager" and check to se if all the hardware is ok.
Use Control panel/netconnections to check to see if you still have a wireless connection and if it works. Also check "My Network Places." Try re-installing the drivers.
As a last resort....try System Restore if it's an XP or Vista system. Remember - using system restore will return the PC to an earlier time but you could lose some stuff so decide first.
Mar 21, 2009 | Acer Computers & Internet
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless-G LinkSys Model WAP54G random Internet Access
RE-INSTALL THE D-LINK USE APATER OR DO DOWNLOAD THE DRIVER OF LATEST VERSION OF IT WWW.D-LINK.COM/PRODUCT.
May 20, 2008 | D-Link Wireless
Wireless light is dark - no connection
Sounds like your router has gone bad. Is it under warranty?
Sep 23, 2007 | Arris WE800G 802.11g/b (498519-001-00)...
Computers & Internet Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
