Question about Philips Computers & Internet
My Philips HTS 3555 won't read dvds or cds. How can I fix this problem?
  • 31 Answers
Clean the lens with tissue, using petrol or thinner.
Posted on Nov 07, 2010
Wont stop reading "no disc" on the display even
If it will play a CD but not a DVD then it could be the Laser is failing. If it won't play either then its more than likely that the Laser has failed.
First thing though is to try cleaning it with a Lens Cleaning DVD.
If after this it still won't recognized a DVD you need to remove the Main Cover followed by the DVD Tray cover. You can then clean the lens directly with some lens cleaner fluid and a QTip. Make sure you only use a little cleaner fluid and wipe off with a dry QTip. Do not touch the lens with your fingers.
After you've reassembled the unit if you still have the same fault then the Laser has failed and would require replacing, although this is not normally cost effective.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS-3555 System
The power supply, LCP106830-0001 is bad. I need a schematic for Philips HTS-3555/37 and new poser supply to repair.
You won't get voltage if you completely disconnect the lcp106830 power supply from the board. The connection to the front panel is required and is used as feedback. I just repaired one and found one of the power diodes faulty.
Dec 20, 2010 | Philips HTS-3555 System
Need a replacement remote control for the Phillips HTS-3555 system, where can i get a replacement remote control
You can buy required remote control for HTS-3555 from Remotes.com
Click above link to see required remote price info.
Thanks.
Sep 06, 2010 | Philips HTS-3555 System
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
My Philips HTS6500 does not read most DVDs. After
HTS 6500 1- OPEN TRAY 2-PRESS DISPLAY 3-ENTER 9.9.9.9.0. 4 CLOSE TRAY. SHOULD WORK .
Sep 14, 2009 | Philips HTS-6500/37 System
Will not play dvds
This is due to the lense problem, when there is "disk error" and "no disk" appears due to defect in the lense and tray with motor problem,
You can repair this issue by technical method by replacing the lense with motor set this will resolve your issue.
Mar 15, 2009 | Philips HTS-3555 System
Plays cds not dvds
Hai,
This is is due the lense and motor section problem, to resolve this issue you need to replace the lense and motor set.
Feb 11, 2009 | Philips HTS-3555 System
Where can I buy replacement connectors?
Have you found them yet? If not go to ebay and look for bogue engineering products, they should have it.
Jan 19, 2009 | Philips HTS-3555 System
Unlock HTS 3555
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control select the region number by pressing the number on the remote (select region 0 for region free) and press OK.
May 05, 2008 | Philips HTS-3555 System
Trying to play hddvd onhdmi player
i don't think this model plays hddvd you will need a seperate player for these discs.
you can only play normal dvds not HDDVDs
good luck
smeags
Dec 31, 2007 | Philips HTS-3555 System
Computers & Internet Logo
88 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
