Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Just cleaned out my father's garage and came up with a Toro 524 snowblower this unit has not been running for over 6 years what should i do to get it up and running? can't find an owner manual online either anyone know where i can get one of those?
  • 718 Answers
You need to clean the carb, make sure fuel lines are not cracked and brittle (replace if necessary) , clean fuel tank thoroughly, especially if there was still fuel in tank. Check for spark, mix a new batch of fuel (if mix is required) and start that mother it will probably run as good as new. Good Luck...
Posted on Nov 07, 2010
  • 3 more comments
  • frazz167 Nov 08, 2010
    thanks the fuel line was rotted so had to replace it. Now just trying to remove the carb anything i need to watch out for when working with the carb other than the obvious? Lots of spark so should run ok once done. One more thing the started has a a pretty loud whine to it when engaged to the flywheel is that normal or does it need to be shimmed?
    Have removed cleaned and replced the carb with still no luck on having the unit fire up. There were a few things i wasn't sure of when reassembling it however. The float bowl does not seem to be seated properly and it now leaks a small amount of gas so not sure how to get that to seat prorpely? There is a needle valve that fell out of the float bowl area looks to be what regulates the flow of gas into the bowl. When i took it apart and i did'n see it until it was too late to view how it was assenbled i re-installed it by hooking a loop of a fine wire attached to it through the flap on the float. that looked to be to way it made the most sense so not sure if i did that right? Anyone know where i can get a manual online for these older toro carbs?
  • vince janis
    vince janis Nov 09, 2010
    http://www.partstree.com/parts/dispdiagi...
  • frazz167 Nov 09, 2010
    the server will not find are you sure this is the correct address?
  • vince janis
    vince janis Nov 10, 2010
    Just do a google search (Toro 524 carb diagram) or what ever model you are looking for, thats all I did and came up with that link.
Only runs for a short time
Jeff, Try running with cap off for a short time to see if cap vents plugged, probable dirty carburetor.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Snowblower Starts Then Stalls
Tecumseh Carb snowblower cleaning 1 of 2
HOW TO Remove Clean Fixed JET on Snowblower Carburetor
Mar 23, 2016 | Toro 1028OXE Power Max 38663 2-stage...
Toro 418ZR runs uneven with choke off
ethanol gas has gummed up your carburetor. take it off and clean it.
Dec 01, 2015 | Toro Power Clear Snowblower 418ZR - 38272
What type of gas and do I add oil to run A Toro Snowblower ccr 3650 65 hp?
there is no such snowblower made . 65 horse power is bigger than a small auto
Nov 12, 2015 | Toro Garden
Other problems know with the toro 1000c 3hp snow blower model 38195
My blower runs fine and has no problem all I do is keep it nice and clean after use and oil the running parts after the season when I dont use it I am very happy with it.
Jan 09, 2015 | Toro Ccr Snowblower
Snowblower leaks gas on garage floor
Is it coming from the carb or tank? Either way replace the fuel lines, they crack an get pin holes in them an cause problems. If it comes from the carb get a rebuild kit an, very cheap, an replace the seals.
Feb 28, 2014 | Toro Powerclear 221qe Electric Start...
How to install the needle valve in a carburetor of a toro 524 model 38040 2 stage snowblower
take bowl of the bottom of carb pull out little pin that holds float bowl on change needle valve put back together make sure you put the bowl gasket on right or it will leak
Oct 11, 2013 | Toro Garden
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
I have a toro snowblower that quit running last year. The screw which held the choke plate in place is missing and I can't find it. Is it possible the screw is in side the motor? I removed the carburater...
Hi
I have seen them go through the engine into the muffler. Did you check the valves if it damaged them. I would check for spark first if that is good put a tea spoon full of gas in the spark plug hole and try to start. If it fires you need to clean the carb. If not i would do a compression test that will tell you if the screw damaged anything.
Sam
Jan 08, 2010 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
267 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
