Question about Cfm 802 Ecofan Table
Ecofan makes a noise - Cfm 802 Ecofan Table
Ecofan not working
The problem is most likely a bad TEG module or possibly a bad fan motor. The most common problem is a failed TEG module. Caframo will not sell replacement TEG modules as they require you to return the fan to them for rebuild but the repair is quite easy. You can find the exact replacement on eBay or directly through Thermal Enterprises. They even have a troubleshooting and repair guide for the fan.
Feb 24, 2014 | Cfm 802 Ecofan Table
Ecofan troubleshooting
Given the age of the unit and the job that it does, it may need to be overhauled and lubricated. This would include removal, cleaning, inspection and replacement of any parts that are worn, lubrication and reinstallation.
Jan 09, 2018 | Dryers
How do i fix my Ecofan ?
Does the motor have bearings or bushings? If bearings, they likely need replaced. If bushings, clean with alcohol then lubricate with 3-in-1 oil.
Jan 24, 2014 | Dryers
Lasko E 20739 does not run
http://www.youtube.com/watch?v=ua6F0Ix04CI try this there is a fuse in the box that could off blown.
Sep 20, 2013 | Cfm 802 Ecofan Table
What is the power system for ecofans - these are the fans / motors which run on electricity generated by temperature differentials in two different and adjacent metals. I would likt to build my own if...
The power source is a thermoelectric module (TEG). Failure of this module is the most frequent cause for fan problems. You can get replacement modules for these fans on eBay.
Mar 13, 2010 | Cfm 802 Ecofan Table
Fan just stopped turning, even if the fire is going good, what could be wrong?
Bushings dried out at rotating shaft. Clean and Lubricate with a high temp. dry film lubricant.
Dec 07, 2009 | Cfm 802 Ecofan Table
The metal strip on the bottom, can it be replaced?
There are no replacement parts for this fan available, however I managed to get mine spinning like new after it had died. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Sep 27, 2009 | Cfm 802 Ecofan Table
Ecofan.going.slow
The most likely problem is either mechanical binding (lack of lubrication) or a bad thermoelectric module. You can get replacement modules for these fans on eBay.
Feb 02, 2009 | Cfm 802 Ecofan Table
My ecofan quit working. Blades rotate rough
Sounds like a bad thermoelectric module. This module is what generates the power to run the fan. You can get replacement modules for these fans on eBay.
Dec 14, 2008 | Cfm 802 Ecofan Table
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Cfm 802 Ecofan Table Logo
636 people viewed this question
Top Cfm Dryers Experts
Are you a Cfm Dryer Expert? Answer questions, earn points and help others
