Need to change mtu setting to 1365 on a Sagem Fast 1704 Windstream router, Xbox live will not work unless I change this setting.
  • Anonymous Mar 24, 2014
    i cant open my router setting what should i do :/
Having the same problem. I found this site that give information about contacting windstream and they will push a firmware update.
http://www.broadbandreports.com/forum/r25059010-Sagem-1704-Wireless-Router-MTU-Issues
Posted on Nov 11, 2010
I want change my password!!!
Posted on Jul 31, 2012
I need an open nat on my sagem 1704 router for ps3 game mw3
I did it with Xbox.
Manually configure your console to have a specific IP address. I set my XBox to 192.168.254.254, with the subnet of 255.255.255.0 and the gateway of 192.168.254.254.
Then (on a computer) I opened my web browser and went to the address: 192.168.254.254
The name and password are both: admin
I clicked Adcances Settings, then NAT, then Virtual Servers.
I created a virtual server, named it, gave it the IP address of my console, and opened up the appropriate ports.
Once I saved it, it worked fine.
How to configure Windstream st 1704N dsl modem router for Xbox live NAT
Apr 02, 2012 | Computers & Internet
The dsl is red and when it turn green i still can connect to xbox live, but when i try to connect my xbox says i need a higher mtu is that possible to change from a laptop
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365. Also you will need to open the ports on the router.
For X-box port numbers are - 53, 80-88, 3074 .
Jan 21, 2011 | 2wire (1000-400108-001) Router
I got it thru Verizon (Westell Model num. A90-750015-07)and i'm trying to set up my XBOX live. It is tlling me that i need to change my MTU setting
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Jan 16, 2010 | Westell Wirespeed Computers & Internet
Need to change nat settings to open for xbox live
you will need to change some settings on the router.
reduce the MTU. if the MTU is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
Jan 02, 2010 | Zyxel P660HW-D1 Router
Can't connect to xbox live party's. I have been told that is a NAT problem but can't seem to pin it down.
DO YOU HAVE A ROUTER?
If you facing problem with X-box.
then you can try yo reduce the MTU settings on the router.
If the MTU is set to 1500 then change it to 1365. disable the firewall on the router.
For this you will need to open the set up interface of the router.
Oct 13, 2009 | Belkin (F5D8231-4) Wireless Router...
Mtu settings on xbox 360
ur xbox will be fine naw it was turned off by xbox for 24h on the 29 th
Sep 30, 2008 | Microsoft Xbox 360 Console
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Xbox 360 live states MTU failed
for some reason i cant connect to live, it says that my mtu has failed. any surgesstions how i solve this??
May 18, 2008 | Microsoft Xbox 360 Console
MTU con connecting. How to fix ?
What does MTU do on Xbox Live?
The MTU of your router or gateway must be greater than or equal to 1365. If it is less than 1365, you won’t be able to connect to Xbox Live.
To change the MTu login to your admin router panel:
  1. Go to start>Run>cmd>type ipconfig
  2. look for "default gateway" then type that address into your router login, usally the login is admin/admin if not look in your manual or call your router maker.
  3. Now login locate the area to adjust the MTU if you cant find it, contact the router maker, or look in your manual.
More info:
http://www.xbox.com/en-US/support/connecttolive/xbox/connectionmethods/diagnosingconnections.htm
Cam
Oct 21, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
4,883 people viewed this question
David Payne
David Payne
