Question about Hunter Ceiling Fan Remote Transmitter 85095-01
Installing ceiling fan with remote transmitter. There are a wire, black, and blue wire that come from the motor of the fan. The remote transmitter change a wire, black, and blue wire to connect to. ON the other side of the transmitter there is a black and a white wire. coming from the ceiling is a black, white, red, and bare copper. I assume black to black and white to white and cap the red. But that didn't seem to work. So I'm at a loss.
bigg t
  • 640 Answers
SOURCE: 2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Posted on Jan 17, 2008
  • 3 Answers
SOURCE: Ceiling fan wiring
Black from the ceiling goes to black from the fan
White from the ceiling goes to white from the fan
Red from the ceiling goes to blue on the fan...if you don’t have a red, connect the blue wire to the black from the ceiling.
The blue is power to the light kit, and sometimes has a separate wall switch, hence the different color. If not, you control the complete power to the fan with the single wall switch (black and white wires) and then control the fan/light with the pull chains
Posted on Sep 09, 2008
  • 75 Answers
SOURCE: Remote Control Ceiling Fan Problem
OK, first off, there have been some problems with those remote units. That said, let me tell you what the wires should be doing and you can see if that is happening.
Normally they take a "Hot Wire" and attach it to the white wire that goes to the switch. It is hooked through the switch to the black wire to bring the "Hot" back up to the light/fan. The whites in the ceiling box are the neutral. A "Hot" and a neutral are required to make anything work. The copper is a ground, or added safety. It usually is attached to the same spot as the neutral in the breaker box, so it is not a big deal. If you have a hot going to the switch which works as the off/on valve, and back up to the box. The hot and a neutral make what ever you hook it to work. Now, if you have a remote, it uses a connection at ceiling box to turn it on and off. You can have a switch to turn the whole thing off and on, but if that switch is on, the remote is just a different way to turn it off.
If you have a way for the electricity to make the big circle, it should work, unless a part some where is not letting it through. I imagine in your situation it is the remote.
If this is new, you may want to see if you can get another, and take the remote part out (Up in the fan) and replace it. You would not have to re-assemble the whole fan. I have replaced several of these lately, and even put a different kind of remote on a few.
Posted on Dec 22, 2008
SOURCE: Aloha 52" Tri-Mount Antique Copper Ceiling Fan Remote installatio
THE RED WIRE GOES TO HOT(BLACK WIRE).THE WHITE WIRE IS NEUTRAL IT GOES ON WHITE WIRE.
Posted on Mar 10, 2009
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
How to eliminate receiver/transmitter in hunter 28425
Open the box at the bottom of the ceiling fan, where the switch is. You should find the receiver inside there. You'll find one white wire connected to it, and two black wires also connected to it. Remove the white wire completely or cap it off with a wire nut. Connect the two black wires to each other with a wire nut. Reassemble the ceiling fan. If the problem was the receiver, then the problem is now gone because the receiver is gone.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Would like some troubleshooting help with a ceiling fan that the switch turns the light on/off but the remote won't control the fan. Can anyone help with wiring questions?
Is the remote control function an add-on to the fan, or is that built into the unit? If it's built in you'll want to go to the manufacturer on that one. As for wires in the wall, black is "usually" the 'live' wire, while white is the cold line. I'm no expert on wiring, but have done some outlets and light fixtures before. Good luck!
Dec 07, 2013 | Dryers
Hampton Bay Carlsbad 52 in. Brushed Nickel Ceiling Fan. I had an electrician install the unit with two different remots and transmitters (1 came with unit and different one) but none of the remotes operate...
either you have a problem with the transmitter or with the electrican this is an easy job not to much can go wroung.lrt me see if i remember hook black to black white to white and hook up ground. good luck
Aug 12, 2011 | Hunter Ceiling Fan Light Remote Control
Im installing a remote to Hunter fan w/light. A White n Black coming from fan, Remote has Red,Black,White n Black n White to go to ceiling.Where do the red,black n white from remote go to on the fan? Thank...
Black goes to the black on the fan white goes to the white on the fan and the red will go to the blue wire on the fan for lights. Now if you have a black wire with a white stripe on it from the fan that is the light wire.
Apr 20, 2011 | Hunter (25417) Ceiling Fan
Remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
May 25, 2009 | Hunter Ceiling Fan Remote Receiver...
Im changing out a ceiling fan.
hook black to black white to white and the blue is a ground wire that you hook to the metal bracket that holds fan in cealing ( anywhere is fine just loosen a screw and place the wire anywhere!
Dec 09, 2008 | Dryers
Ceiling fans..
Are you talking about the receiver? If so connect wires from fan, White, black,blue to receiver white, black, blue. White to white and so on. Then connect the two wires from other side of receiver, white and black(or Red) to corresponding colors from ceiling. Then store receiver just above the ball in the ceiling mount plate, you will have to move the wires to the side and push it in. Hope this helps
Aug 16, 2008 | Dryers
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Dryers Logo
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
