Question about Kenmore 64892 Electric Dryer
How to remove contril panel fron kemore 88052 front loader dryer model # 4170052700. spilled detegent on top went down panel now doeas't work need to clean.
  • 8,197 Answers
On link below will help you remove the control panel. Read in full before you try to remove.
http://www.repair-help.com/kb/file_d.php?id=4
Good Luck
Posted on Nov 08, 2010
How do you take off the front panel/cover
need to know what washer you have, make and model, but generally take off top, or release front of top and lift it up and back, then remove control panel if front loader, and then remove front.
Sep 08, 2015 | Dryers
How do I remove the face plate of the dryer
what make amd model dryer? as a general rule first UNPLUG the dryer, if it is gas turn off the gas supply then you have to remove the dryer door first for front loaders. Once that door is off look for any additional screw that were hidden, there may or may not be any. Then look for any brackets that may be attached to the top panel of the dryer. If it is a top loader skip that, then you pry the top of the dryer up they are usually held down by clips. Then grab/pry the front of the dryer off. Those panels are held on by clips also but take a look for any brackets that might have screws in them. It should all be visible.
Dec 17, 2014 | Dryers
How do I get to the belt moter on a sears Kenmore 500 cloths dryer the belt is off but not broken
The usual method of accessing the belt is to remove the entire fron panel (including door). It is usually easy to remove the panel by removing a couple of screws at the top and pulling up and out on the panel. The belt can be reached from the front. All dryer belts have a spring loaded tensioner on the belt. Check the tensioner as belts hardly ever come off unless the tensioner spring breaks.
Oct 20, 2014 | Kenmore Dryers
HI I HAVE A DRYER MODEL DLG5988WM I WOULD TO KNOW HOW TO REMOVE THE FRONT PANEL
Step 1, remove dryer top: remove three phillips head screws from the back edge of dryers top.
stand in front of dryer and push back sharply about 2 inches on the dryer's top using the palms of your hands. Lift top up and off.
Step 2, remove control panel: remove phillips screws from back side of control panel corners and release clips along top edge of control panel, allowing panel to be taken off and set on top of dryer.
Step 3, remove front panel: Open door, remove phillips screws located at 4 and 8 O'clock positions at door opening. remove phillips head screws along fron panel's top edge. tilt panel forward and unplug light, door switch, and moisture sensor (at bottom of panel) and then set panel aside and out of your way.
Feb 03, 2011 | LG WD-3243RHD Front Load Washer / Dryer
After draining drum does not spin
use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, remove the two top inner screws and the front will remove.
sounds like the belt could be the culprit
Apr 01, 2009 | Admiral AW22 Top Load Washer
Broke start button
Look inside door and get the model number for me. Replacing the start switch is easy. From back cover inside the top control panel. Let me know, Thanks Sea Breeze
Mar 20, 2009 | GE Dryers
41780042990 Kemore electric dryer
you would need to "punch out the metal" , youl also need to remove the fron tof the unit(2 screws approx 3-4 inches down form inner panel, holding front panel on, ( youll need to remove the top of the dryer( a few screws across the back of unit.) andthen disconnect the dryer belt(easiest acess through a small acess panel on lower rear of unit, pull the dryer drum out and youl see the existing ve, just a matter of attaching a 90degree elbow and running vent out the side instead of out the back. DISCONNECT POWER TO UNIT FIRST!!!!!!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
The rubber seal on the kenmore elite he 4t front loader has a rip and water spills on the floor how do i repair it.
remove the top of the dryer, the bottom assess plate the console the frount panel the fbric despenser dwawer, unbolt the door latch best to remove the door from the frount panel pull arround on the lip of the seal the part that is holding it to the frount panel
once the frount of the seal is loose from the frount panel remove the frount panel and set aside
remove the spray tube from the rubber seal center top of seal
remove rear clamp
reinstall in reverse
Apr 25, 2008 | Washing Machines
HOW TO UNSTACK A WASHER AND DRYER
Chainsaw, no seriously the dryer is bolted to the washer and not all of them can be unstacked. Remove the front panel of the dryer to expose the bolts holding it down. this only works if your washer is of the front loading type. if it is a top loader there should be some sort of frame the dryer is bolted to. after removing the dryer from a front load stack washer, the washer may or may not have a top panel on it
Sep 02, 2007 | Dryers
Kenmore 64892 Electric Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
