Question about Sony Televison & Video
Oval shaped dim / discolored spot on the right side of the screen of 70" projection tv. problem persists after replacing bulb. could it be a fine layer of dust on the projection receiving lens?
  • stevec900 Nov 07, 2010
    Model # is KDS-R70XBR2. I have since learned that there is a class action suit on this unit, recently settled by Sony, for defective optic blocks. Sounds like the offending part I am trying to describe as the "receiving lens". What do you know about this suit?
  • 10,594 Answers
If that spot is not tinted like bluish, reddish or greenish etc and looks blackish then it is dust layer at first lens/ filter located next to lamp or tv screen is dusty inside.
Let me know model number of your Sony tv and little more info about spot would be helpful to diagnose its cause.
Can you post image of screen that shows spot? Please note image should be under 150k jpg to post in question thread.
Thanks.
Posted on Nov 07, 2010
  • Shahid Electronics
    Shahid Electronics Nov 07, 2010
    Yes, there is class action suit against this model, click Sony Support link for details.
    Call Sony to fix issue in tv either it is lens or optics block cause of spot.
    Thanks.
Discolored Sides
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Ths if your tv is a dlp if its a Lcd it will be an issue with your light engine: Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Mar 29, 2010 | Televison & Video
Black spots on screen
I posted this answer to a similar question someone else had, but it looks like you have the same problem...
This sounds like your optical block is failing. This is a very expensive part to replace, so much so that it may be better to just buy another TV. Sony has had some tech problems it seems with these; here is a link to some further info:
http://sites.google.com/site/sonylcdrptvproblems/#TOC-Optical-block-discoloration-issues
There is loads of info on this page about your issue and other problems and Sony's remedy (if any) for reimbursement. Good luck.
Mar 27, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Noise problem related to dim pulsating light
this is caused by the motherboard on this model,have replaced many lately,what happens is when a light bulb in the refrige compartment burns out it creates a surge and burns this circuit board,the clicking is a relay on this board trying to latch,but when the board is defective it cant,when you remove this board it will have a burnt spot on the boards circuit trace and a discolored spot on the case holding it
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
New lamp restored brightness and color levels...but there is a large oval area of green tint on the screen...tv is rather dusty inside...any ideas
did the bulb break or just get dim? if the bulb broke then you might have a piece of glass down in the engine if the bulb just got dim you might just have a piece of dust down in there you really should have atech take alook or you could damage your engine and that would be around 500 dollars
Dec 11, 2009 | Hitachi 60VS810 60" Rear Projection...
62.in hitachi projection t.v. has yellow oval shape in center of screen dark blue color on rest of screen picture fine just color
A discolored Blob, loss of one color or blotchy pattern usually in the center of the screen. The problem is becoming all too common with Hitachi projection sets. What happens is that one of the lenses in the optical block (or light engine) starts to burn or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far-gone except to replace the light engine-at a cost that makes it not worth repair. if the damage is minimal than to reduce further damage, the air filter should be replaced. The Light engine needs to be removed in order to replace the air filter. Be sure to vote/rate me if this helped Thanks!
Also see link:
http://fyshere.blogspot.com/search/label/Hitachi%2050V500%2050%20in.%20HDTV-Ready%20LCD%20Television
Oct 23, 2009 | Televison & Video
Blurry screen on 50in Hitachi LCD
Sounds like you need a bulb replacement, if you watch tv a lot ave life is about 5 years
Sep 14, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Picture is dim and blurry
The screen probably needs to be degaussed, which will require either a degausser or a technician. Try turning the television off, and then unplugging it from the wall outlet. Then replug after 30 seconds and turn it back on. Also, try plugging any cables from a cable or satellite box into another set of in-ports on the back. If the problem persists, the screen needs to be degaussed.
Feb 22, 2008 | Philips 51PW9303 51" Rear Projection...
Toshiba Projection Picture discoloration
burn in on one of the tubes try magic focus?
Mar 12, 2007 | Toshiba 65HDX82 65" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
