Question about Poulan Pro 14" Gas Chainsaw 33CC P3314
How do you adjust the carborator on a 2.5 stihl chainsaw?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 338 Answers
Most Stihl carburetors built after 2000 have limiter caps that prevent much adjusting. the standard for adjustable carburetors is 1 turn out on both high and low then set rpm of idle and high end to specs.
If you need to adjust the engine to get it running there is a problem somewhere else in the systems.
see a dealer like www.arcolawn.com for help.
good luck
Posted on Mar 28, 2011
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
How do I reset carb. screws to factory settings
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws and other two-cycle engines. ... These saws have what is called a "fixed jet" which is set from the factory. ... (7) Go back to step (5) and reset the idle speed. ... NOTE: If you do not have a tachometer, set the RPM level so that the saw "four ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
Return a type A carburetor to its factory setting by turning the "H" screwcounterclockwise until it ... Where Do I Find the Carburetor on My Stihl 017 Chainsaw?
how to adjust carbs on 2 stroke weedeaters and chainsaws ...
Dec 25, 2015 | Garden
Could some help me with factory carb settings on this saw
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
How to adjust chainsaw oiler on stihl MS230
you cant. the oiler on an Ms230 is preset and non adjustable. Make sure the oil worm gear isnt damaged
Apr 13, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
The carborator iss not adjusted
The idle screw is in the hole right above the primer bulb. Turn clockwise to increase idle. Adjust in small increments.
May 08, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hello, my stihl 017 chainsaw is over oiling the bar, is there any adjustment I can perform, thanks, Gareth.
No oiler adjustment. Sorry
http://www.stihlusa.com/stihl_ownersmanuals/017_018_Manual.pdf
Are you using bar oil or something lighter? Stop by your local Stihl dealer (leave your saw in the car), give him a latte, and chat. He might have an idea or 2. He will not be chatty on any weekend or if there is a perspective sale in the store, HTH
Lou
Jan 19, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl ms310 chainsaw will only run on choke
You actually need the adjustment tool,looks lie a small screwdriver with a smal socket at the end of it.
Jun 02, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Poulan Pro 14" Gas Chainsaw 33CC P3314 Logo
232 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
