Question about Dell Studio One 19 PC Desktop
I need to open the computer to see what it got inside
  • 1,179 Answers
Rather try software it's quite accurate and it is much quicker. Right click My Computer and select properties. This will bring up your computers CPU speed, RAM size installed and the version of operating system. Then to see the size of the hard drive, double click my computer and right click your hard drive, then select properties. This will show how much space is available as well as the capacity of your hard drive.
Click here to download CPU-Z, it will give you detailed information about your CPU, RAM, Mainboard and Graphics.
Very use-full program to have available.
All the best, Thumbs up!!!
damnor01
Posted on Nov 07, 2010
I have a new pixma mp258 printer but i can't install it using a cd cause my cd drive is busted, so i need another way to install it
try to insert your CD in another PC and open it from my computer by clicking start/my computer/right click CD/DVD drive/click open or explore/copy the files inside of the CD installer including the setup.exe and the driver into USB flash drive.then insert your flash drive on your PC.open it double click the setup.exe or the driver folder.inside the driver folder should have an exe to install the software.
Sep 23, 2011 | Computers & Internet
My Toshiba ts-h653 cd/dvd RW drive failed w/DVD inside
ur desktop needs to be open at all cost otherwise no solution
Nov 30, 2017 | Computers & Internet
Placed on different computer upon opening goes to sleep won't open
If it has the same problem iwth moe than one PC's then you will need to open it up and inspect the inside. Please read below so you will have some ideas on what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Samsung 943bwx . blue light just blinks and get no display. tried diff computers and no luck
Time to open it up and inspec the inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 11, 2010 | Samsung 943BWX Monitor
I have a Samsung monitor, model #953BW. I put the computer to sleep last night and this morning the monitor will not display anything. It is the monitor, not the computer, as another monitor works on that...
At this point you need to open up the monitor and inspect the inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 06, 2010 | Samsung 226BW Monitor
My Soyo DYLM1986 won't come on and is clicking inside. I have rebooted the computer, disconnected & reconnected from the CPU & monitor. Can you reccommend anything to help? Cindy
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Soyo DYLM1986 Monitor
ViewSonic VG1921wm no picture
You will need to open it up and inspect the inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | ViewSonic VG1921wm 19" Monitor
MT COMPUTER MONITOR FLASHES ON AND OFF ALL THE TIME
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | MPC Computers Envision EN 5200e 15"Flat...
Need to open my toshiba laptop L355D S7815
GO TO WWW.9MANUALS.COM AND THEY HAVE THE LABTOP DIAGRAMS AND SETUP AND DRIVER REQUIREMENTS AND THE PART TO FIX ANY LABTOP
Mar 14, 2009 | Computers & Internet
I can't open a disk from the d : drive
Try this: Open up "My Computer" and look for the CD. If you see it in there, double-click on it to open it.
In XP, My Computer is either on your desktop or inside the Start menu, on the right.
In Vista, My Computer is inside the Start menu, on the right. (Vista has known problems with the Autostart function on CDs).
Jan 08, 2009 | Toshiba Satellite L305D-S5895 Notebook
Dell Studio One 19  PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
