Question about Whirlpool LEQ9858P Electric Dryer
Dryer coming on and heating element works, but the drum is not spinning. Is this a simple fix or is it cheaper to buy a new dryer?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 15, 2011
Were do I find the heating element on a Samsung dryer
The element is located inside of the dryer. In order to access it you will need to remove the top cover, the control panel, the front panel, the drum support, then finally the drum itself. If you have any mechanical aptitude and can stay organized you can do the repair. It is much easier to watch a video on how to access and test the components. If you have no heat, you stand a great chance of needing a new heat element. You can buy one that comes with the canister and is quite simple to change out or for less money you can buy just the element itself and take a few more screws out and change the element. I warn you while it is low on the skill meter it can become high on the frustration meter.
Jun 03, 2018 | Samsung Dryers
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
This is a Bosch electric dryer that is 10 years old. The heating element is gone. Is is worth fixing? Or should I buy a new one.
are you sure it is the element, and yes repairing it is a whole lot cheaper:
http://shop.ebay.com/i.html?_nkw=heating+element+dryer+bosch&_sacat=0&_odkw=heating+element+dryer&_osacat=0&_trksid=p3286.c0.m270.l1313
this should assist you:
http://www.espares.co.uk/advice/tumble-dryers/a/9/1344/how-to-replace-the-heating-element-assembly-o.html
Dec 03, 2010 | Bosch Axxis WTA4400 Dryers
My Dryer has power, spins the drum, but only air
Well I know that older dryers came with a wiring schematic for where all the wires go, but yours may not. There is a lot of experimenting with dryers when it comes to diagnosing. I would say that it is very possible a door switch could cause that depending the position its stuck in. If no power is going through that switch then the heating elements may work off of whether that switch switch is operating or not. If your heating elements worked before this then I would have no doubt that they are working now. If the switch being replaced doesn't work I would then go and check for full voltage at your main terminals (120V per power wire and 240V across both of the wires)
May 10, 2010 | Kenmore 62722 Electric Dryer
My Haier clothes dryer (HDY-C70-F) spins but doesn't heat, then displays an ''E2'' error. Could it be a simple fix I can do myself?
Guess the answer is too late for you, but for others:
E2 means that the heating element is broken. You can buy a new heating element and replace it. Unscrew the backpanel and you see an aluminium block which looks like a radiator. Replace this by the new element and you are ready to go.
Don't know what the price is though.
Nov 25, 2009 | Haier Dryers
Leaking from the bottom,water all over the area in garage,when spinning makes a rubbing gear noise,the dryer isn't much better,the drum continues to turn when the dryer is OFF,this pair cost a small...
this could be as simple as the drain hose has come loose from the pump. Otherwise you may need a new gasket arounf the pump it'sself. as for the dryer issue, there should be some type of batting or fabric around the drum to help seal the heat in the drum and provide resistance to the spin. If that is gone or loose, the drum will continue to spin a few times after moter shuts off.
Oct 11, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Dryer is not heating, only blowing cool air
Its best to take it to an appliance repair man. This is usually an electrical problem related the the board or the relays behind the control panel. Beware though, sometimes its cheaper to buy a new one than fix the old. Hope this helps.
Sep 13, 2009 | Uniden Cordless Phone
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Mar 08, 2009 | Dryers
Dryer won't spin
This may be a simple broken belt problem. The dryer utilizes a belt that wraps around the drum and is driven by a motor. If the belt breaks, the dryer heating circuits will still finction normally, but the drum will not rotate. It would be helpful if you could provide me with a model number (located somewhere around the door opening, or along the back of the operator console). If it IS a belt problem, this is a fairly inexpensive fix. If the motor, however, has gone bad, it may be considerably more. Please post back with your comments. I hope this helps you.
Jan 17, 2008 | Dryers
Whirlpool LEQ9858P Electric Dryer Logo
29 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
