Question about HP ScanJet 2400 Flatbed Scanner
How do I clean my scanner screen? - HP ScanJet 2400 Flatbed Scanner
  • 31 Answers
Http://www.ehow.com/how_14267_clean-scanner.html this link will help u, regards
Posted on Nov 07, 2010
Have a hp 3330. It stops working and the screen reads "scanner error"
same issue here , i solved with cleaning the scanner mirrors .
you get the scanner to the left where you see the glass (on off repeatedly)
open the little glass on the left
with Q-tip and alcool clean the 3 mirrors (little in left/bottom ps- big in bottom position-an one in right)
bye
Jan 29, 2011 | HP LaserJet 3330 All-In-One Printer
The error message on the printer screen says: scanner error 22
The error is scanner error check the scanner in moving or not if not then check the scanner cable is broken or dust on scanner rod clean oil it properly
Dec 28, 2010 | HP LaserJet M1120 MFP All-In-One Printer
How do I remove and clean the glass?
mcdevito75 here, Check with your local Radio Shack, Staples for a product used to clean Scanner screens. I wouldn"t attemt to remove any portion of the scanner a s it could cause dammage.
Jul 07, 2010 | Umax Astra 3400 Flatbed Scanner
When it scans it leaves a black line on the document and on the computer screen.
The black line is either caused by dirt build up on the scanner glass (clean the scanner glass) or one of the bulbs on the scanner lamp is burnt out.
Mar 24, 2010 | Lexmark X4875 All-In-One InkJet Printer
Black line on image
It's possible that the black lines you're experiencing are an internal image adjustment issue with the scanner itself. If the scanner glass is otherwise clean, try going to the Canon DR2050/2080 utilities installed as part of the set up of your scanner and running the Adjustment Tool - it asks you to place the "adjustment paper" in the scanner. The term, "adjustment paper," appears to mean anything which has an image or text on it. Be sure you clean the scanner first before running this utility. It will have you put the "adjustment paper" through twice, and that in turn should remove the black lines in your scans, as long as there is no dust on the scanner glass. Office Depot sells cleaner sheets for laser and inkjet printers which also work on faxes and scanners and which will clean the glass for you.
Nov 08, 2009 | Canon DR-2050C Path-Through Scanner
I have just re-installed my acer scanner after approx. 2 years of non-use. as I plug the power in the green light comes on , flickers for a moment or two and then goes out. when i click on the Mirascan...
Replugged it remove it and clean it and then plugged it again and then check what message comes to u r screen if the message comes so install it one more time or if it would not connect so change the port of plug and then restart u r pc and try that problem will solve
Jul 25, 2009 | Acer S2W-4300U Flatbed Scanner
Green Screen Happens when I Scan
just clean the both inner mirror and the scanning lamp of the scanner. it will star working. Remember use clean and dry cotton cloth for cleaning
Jun 17, 2009 | Microtek ScanMaker 3800 Flatbed Scanner
Blank screen goes in and out
My 2096 was doing the same thing with a blank screen. IF, your scanner is scanning normally and the dim button still dims your display, your problem could be the same as mine was. This worked for me and got my display working like new again. First thing to do is to take the covers both top and bottom off to expose your scanners insides.Next, once you can see the inside of your scanner you will see a ribbon cable connected to the main board and also soldered to the display. Take the ribbon out of its coupling connector and gently clean the contacts on the ribbon with a cuetip with alcohol on it, also clean the solder joints on the display face that connect the ribbon to the display with the cuetip and alcohol. Ii then reassembled everything, ribbon back into its connector and made sure the clamping mechanisim on the ribbon was securely holding the ribbon. I pluged the power supply into it and turned it on before reassemblig the case covers to see if it would work. Bingo, it worked like new again. Hope it works for you ! Jim
Nov 04, 2008 | Radio Shack Pro-2096 Base Scanner
Vertical dark line on copies
That is comming from the scanner. If cleaning it well does not help, then it is one of the segments in the CCD assembly within the scanner that is the problem. That would requiring replacing tha scanner .
it could be a small scratch on that screen also.
Only thing you can try would be use some rubbing alcohol and a regular piece of 20 pound copy paper to clean the scanner glass/screen vigorously.
Mar 21, 2008 | Brother MFC-970MC Plain Paper Thermal Fax
Help !! ,Microtek scanmaaker 3840 problem
maybe you have to clean up your scanner.. and ur settings of scanner might have the wrong configuration....
Feb 24, 2008 | Microtek scanmaker 3840
HP ScanJet 2400 Flatbed Scanner Logo
79 people viewed this question
Seeker5211
Seeker5211
