Question about Kenmore Washing Machines
Had washer 12 years. Model 110.25862400. Fills and now nothing will happen. Have not changed ffrom cold/cold setting.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11025862400/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Nov 08, 2010
Fridgeaire washer dryer stack unit. The washer side doesn't complete cycle.
check door lock switch if not water valve for cold side is not on or valve is defective buzzing sound from water valve means not opening
Jun 27, 2016 | Frigidaire Washing Machines
My washer will just fills and quits
Whirlpool, Maytag, kenmore - Washer Repair - Fills Then ...
? 9:17
www.youtube.com/watch?v=TBeymPFyYWo
Sep 12, 2013 - Uploaded by ApplianceVideo.com Repair your Whirlpool Top Load Washer with these following problems: Fills Then Does Nothing Only at
Sep 24, 2015 | Washing Machines
Why will my ghwn4250dww not start
You say no start. Does it attempt to fill with water. If no water---possibly a bad inlet valve which is the part the house hoses attach to. It is a 2 part valve with a hot and cold side. If no fill and you are on hot wash, switch to cold wash and see if it fills. That will tell for sure you have a bad valve. If it fills and then does nothing we have a different set of problems. Let me know exactly what is happening.
Aug 10, 2014 | GE 3.9 cu. ft. Stainless Steel Capacity...
My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
Hi there. I can help you.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
Jun 18, 2009 | GE WSXH208A Front Load Washer
Kenmore washer 24802, model 110.92480200, serial # cce3564876. cycling stops after wash and before rinse
This is normaly because your cold water inlet soliniode is faulty. If you want to test it set the wash temp to cold and start the machine, It should do nothing. then set it to warm or hot wash and see if it fills with water if so the cold inlet soliniode needs replacing
Jan 22, 2009 | Washing Machines
Cold water not running.
check the cold water selenoid on the water valve
May 05, 2008 | Washing Machines
Washing Machines Logo
318 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
