Question about Cameras
Will not flash...even with new batteries.... ERROR 20000 PLEASE HELP ME....
  • bwodal Nov 07, 2010
    Moultrie game camera...mod. # DGS 140
    No night pictures...only day light pictures...errow shown was Error 20000
  • 10,515 Answers
Kindly mention the make and model of the camera. Also, explain the problem in detail.
Thanks!!
Posted on Nov 07, 2010
  • taran_2005
    taran_2005 Nov 07, 2010
    Thanks for your response!!
    This is a common problem on these models.It means
    that your flash is not working. Moultrie will advise you to cover the
    day/night sensor while running the diagnostic test, and that that will
    fix it, but it may not do so.
    means
    fix it, but it may not do so.You could try to update the software.If that does not solve, it would most probably confirm a faulty flash unit.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
I am asking anyone who has firmware for casio ex z40, to help me clear the system error. please send it to me to my email address(tonnyagit@gmail.com)
Sorry, we don't send e-mails. Only when you have the right tools and software to flash a camera from Casio, you could use firmware. You can't put in there firmware, when the camera is not 100% functional. Once the flashing of the new firmware starts, it can't be stopped, because it is writing new software that has no connection with the older software. And a part of the old with a part of the new software does not make one correct program. So NEVER try to solve a system error with a update. The system error must be repaired by a pro.
Mar 05, 2015 | Casio Exilim Cameras
New batteries but wont turn on
Try the following:
1. Ensure the batteries are indeed, charged. Sometimes even new ones are bad.
2. Ensure battery polarity is observed when loading batteries.
3. Make sure the flash ON/OFF switch is not loose or damaged.
4. With the flash mounted on your camera and the power switch to ON, try resetting the camera to factory default settings. This MIGHT clear any errors and allow the flash to work.
Oct 10, 2013 | Canon Speedlite 550EX TTL Flash
I have a MFH-I-40 camera. The camera stopped taking images and is reporting Error # 20000. What is the problem?
Hi.
Moultrie error code 20000 means that your flash is not working. Moultrie will advise you to cover the day/nite sensor while running the diagnostic test.
Some people have fixed the error by removing the batteries while the camera is switched on and then reinserting them.
Regards.
Jun 08, 2011 | Moultrie Cameras
If x units of a product cost C dollars to make and revenue of R dollars, the value of x where the expression for C and R are equal is called the break even quantity, the number of units that produce zero...
Set C = R
This means 16X - 20000 = 14X
Add -16X to both sides
-20000 = -2X
Divide both sides by -2
10000 = X
This means that the break even point is 10000 units.
Oct 10, 2010 | SoftMath Algebrator - Algebra Homework...
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie DGS160 Game Camera Error 20000
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Oct 03, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Directv universal remote
ok i have a sylvania tv/vcr combo, similar problem, here's how i got the directv remote (RC23 & RC32) to operate basic t.v. functions:
-First i found the code that worked for the vcr (20000 in my case).
-i programmed "AV1" to 20000, this allowed me to power the tv on/off, change the channels but not operate the volume, so...
-after plugging in the 20000 code (with the slelector switch on AV1 still):
1. Press and hold the MUTE and SELECT keys until the
green light under the TV position flashes twice, then
release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press select
that allowed me to operate the t.v. volume from the remote w/ the selector switch in any position, the only thing is i have to switch to AV1 in order to power off the T.v.
hope this helps in your case
Jan 31, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Oracle error codes
are you working in programmed oracal software or direct oracle?
Sep 25, 2007 | Computers & Internet
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
