My laptop froze so i had to hold down the reset button and turned it back on it came to this screen that said safe mode or normal mode to restart it i did both but it keeps bring up this blue screen and restarts and does the same thing over. i need help or a solution on how to fix it??
    Problem Solver:
  • 18 Answers
I would try holding down F8 when turn it on and find lastknow configuration
Posted on Nov 07, 2010
My del studio laptop doesn't shut down
You could have a corruption in the script or a process that won't stop. Try holding down on the power button until the screen goes dark and all lights go out. That is a hard shut down without saving settings. After it shuts down (finally) power it back up. Hit the F8 key on your keyboard the moment your machine goes to the black screen before it can load windows. That is the safe mode. Move the highlight up to safe mode or safe mode with networking and allow it to continue to boot up. Then, when it's completed the process and windows displays that it is in safe mode, do a normal restart. That should resolve the issue.
Oct 22, 2013 | Dell Studio 1737 Laptop
Downloaded quicksilver for net flix on mac...froze screen
Hi Siszee,
Yea, that happens.. it's a microsoft product...;-(
simlply restart your mac in safe boot mode ( hold down the shift button immediately upon hearind the startup sound... hold until you see a progress bar under the Apple Logo ) you will be able to login and re-install QuickSilver.. should do the trick..
then restart normally
Oct 15, 2013 | Apple 24" iMac Desktop
So my laptop froze yesterday and I turned it off to restart it. When I restarted it it everything was normal but after the starting windows goes away it usually goes to the login page well now all it does...
Try starting it in safe mode.
When the computer is starting just after the beep or when the bios info goes away press f8 repeatedly and you will get an option to open in regular or safe mode.
Alternativly you can also hold down teh ctrl key and it should do the same.
Did you install or update and drivers recently?
Aug 25, 2011 | Compaq Computers & Internet
Asus aspire laptop has black screen w 2 windows 1 has @ top says administrator:cmd.exe the other says safe mode in all corners how can i fix this
Your computer has booted into Safe Mode. A simple restart should fix and boot it back to normal. If it boots back into Safe Mode, Shut it down, then turn it back on while holding the Escape key. On the screen that comes up use the arrow keys to select Normal Startup, and press Enter.
Mar 23, 2011 | ASUS Computers & Internet
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using it...
holding the fn key on boot will start the pre boot diagnostics if theyre clean then the heatsink and fan need cleaned out as they get blocked with dust, there should be a panel that you can remove on the back
Feb 24, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using...
Make sure the cooling fan for the laptop is not obstructed in any way or is not dirty. It's pretty common for a laptop to get plugged with dirt from normal use. Get a can of air and blow the machine out to remove dirt, lint or debris.
You could also have a defective battery, but try cleaning the machine first.
Feb 24, 2011 | Computers & Internet
Hi! Computer screen froze when shutting down, I turned it off, turned it back on and now it is stuck on "start up repair" screen, for hours! Help!
Restart it and try start windows normally.
If that doesn't work, try safe mode and restart the computer.
Nov 20, 2010 | Computers & Internet
I have an Asus G1 laptop and I was just on it when the screen froze and an error message appeared saying the display adapters were not working and then the screen went distorted and froze so i reset it ...
Press F8 when you turn on the computer and from the list of options select safe mode and boot into safe mode when you are on the desktop screen go to the device manager ( you can use this path : start-run-devmgmt.msc) in the device manager go to display adaptors right click it and uninstall it.
after that restart the computer.
if this doesnot work again boot to safe mode and try to do a system restore (start-all programs-accesories-accesibility-system tools-system restore)
select a date when your system was working fine, that should fix it.
Mar 10, 2010 | ASUS A8Jm Notebook
HP Pavilion laptop restarts during welcome screen
Do the power drain
step1. Remove battery and ac adapter
step2. Hold on to power switch for 30secs-1mint
step3. Put back the battery and ac adapter
step4. Start the laptop as usual
IT SUD BOOT PERFECTLY
after doing this also if the symptoms are same
i apologise to tell u ...its gonna be Motherboard probs which is common nowadays in Most of the HP LAPTOP
Feb 21, 2009 | HP Pavilion dv6000z Notebook
Having Trouble Starting
Enter Safe Mode with Networking.
Update Video drivers.
Restart the system in normal mode and if still no go then you have to reinstall Vista from CD's.
Sep 25, 2008 | Toshiba Satellite A305-S6834 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
