Question about Dimplex Compact Electric Flame Stove Heater
Heater component does not turn on. Model no. CS3311 mod c Serial no 20609d2f 033. Is there a fuse?
  • mbuckley11 Nov 07, 2010
    Guess I needed to wait.
  • 6,826 Answers
OPERATION (FIGURE 2)
A. Main On/Off Switch
The switch has two ON positions marked with and "Manual".
The "Manual" position is for manual operation. In this position the built-in remote control is by-passed.
The position is for operating the unit with the provided remote control. When in position the unit
is operated with the ON and OFF buttons of the remote control.
When the switch is in the center position the unit is off.
B. Heater Switch
The HEAT ON/OFF SWITCH supplies power to the heater fan and the heater element. When the
switch is in the ON position the heater operates if the thermostat calls for heat.
C. Heater Thermostat Control
To adjust the temperature to your individual requirements, turn the thermostat control clockwise all the
way to turn on the heater. When the room reaches the desired temperature, turn the thermostat knob
counter clockwise until you hear a click. Leave in this position to maintain the room temperature at
this setting. For additional heat, turn clockwise until you hear the click again and the heater will turn
on.
NOTE
When the heater is switched ON, the heater fan will operate. The heater element may or may not be
on, depending on the thermostat control setting (SEE "HEATER THERMOSTAT CONTROL").
RESETTING THE TEMPERATURE CUTOFF SWITCH
Should the heater overheat, an automatic cut out will turn the heater off and it will not come back on
without being reset. It can be reset by switching the MAIN ON/OFF SWITCH to OFF and waiting 5
minutes before switching the unit back on.
CAUTION
If you need to continuously reset the heater, unplug the unit and call Customer Service at 1-888-346-7539.
Posted on Nov 07, 2010
  • Duane Wong
    Duane Wong Nov 07, 2010
    Thanks for the rating and hope the product works after waiting.
Can't find the window fuse for 2003 caddy cts
Check inside trunk under carpet on rear seat back support.
Nov 12, 2016 | Cars & Trucks
I HAVE 2400 WATT DIMPLEX BUH24T FLOOR ELECTRICAL HEATER APPROX 20 YEARS OLD WITH FUSED 3 POSITION WALL SWITCH. I AM REPOSITIONING THE HEATER AND NEED TO CONFIRM THE INTERNAL WIRING FOR THIS SWITCH. THANK...
20 years old! I serious doubt that there is an Owners Manual or schematic still in existence, However, if you want to give it a shot call DImplex Customer Support to see if they can help you.
If you live in the UK call 0845 600 5111
If you live in the US call Dimplex Technical Service 888-346-7539
Hope this helps you find what you need.
May 24, 2011 | Dimplex CS3311 Compact Heater
Htn20 how do I change the light bulbs
It's not difficult to do on your Model Electric Stove/Heater. However, if you have a drawing to look at, it makes it easier. So, in case you have misplaced your Owners Service Manual go to the link below and your can download and print it for future reference.
http://partner.dimplex.com/files/domain4103/7207400100r05_EN.pdf
Hope this helps you solve your problem.
Feb 17, 2011 | Dimplex CS3311 Compact Heater
I need a terminal block for a Dimplex CS3311
can you be more specific? what kind of terminal block? what do you need to use it for? it seems like a lot of people are having problems with their dimplex 3311
Feb 02, 2011 | Dimplex CS3311 Compact Heater
Light stopped working
the lightstopped workingon Dimplixcs3311 compact heater? please help!
Nov 01, 2010 | Dimplex CS3311 Compact Heater
The driver seat heater just quit. all fuses are good. how do you tell if the relay is good?
Swap it with a relay you know to be good and see if it works again,pick a relay that is not important to the function of your car.
Nov 01, 2009 | 2004 Cadillac SRX
Dryer no heating, air flow good..
Hello Gamoneda,
Since you are already able to access the components in your electric dryer..( Always remove or disable power before taking any measurements like this).. Unhook the heater element itself and measure for continuity through it. You will probably get somehwere between 5 and 20 ohms ( model specific) when that element is cold. You could also have a bad upper limit thermal switch or non-resettable fuse has opened but if you are measuring any of these components for continuity.. make sure you detach any wires that are plugged into them.. If you don't do that, then you could might get false measurements by reading something that is wired in parallel with them. Hope this helps..
Regards,
Rick
Nov 20, 2008 | Dryers
Dimplex Compact Electric Flame Stove Heater Logo
492 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Naveen Sistla
Naveen Sistla
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
