Question about Seca 884 Certifiable Electronic Personal Digital Bathroom Scale
I have a SECA 884 and when I get on it to get the numbers on the monitor keep fluctuating. It does not give me my weight. How can I fix this?
  • 1 more comment
  • sdiazjr Nov 08, 2010
    I changed the batteries and the scale still is not working properly.
  • leona kadir Feb 25, 2012
    my 884 scales have alayws worked perfectly but suddenly the numbers keep changing and it doesn't ever stop. it is fluctuating by around 5-6lbs and just keeps changing. I've tried taking the batteries out and putting them back in but nothing is helping.
  • 19,396 Answers
Hi.
Reset the scale by removing and putting back in place the batteries.
After putting the batterieas back in the slot, perform procedure below:
Place the scale on a level surface.
Ensure that only the feet of the scale are in contact with the floor. The scale may not be in contact at any other point.
If an uneven floor (e.g. thick-pile carpet) contacts the base of the scale, push on the carpet feet supplied (see Fig. 5).
Here an online user manual.
Regards.
Ginko.
Posted on Nov 08, 2010
    President:
  • 2,777 Answers
Have you attempted to just change the batteries out on this scale? It is a very high end scale here, and should last a good while. If you changed the batteries and it still is having problems then the actual scale is having issues. It may still be under warranty, and even if it's not it can be fixed. Just give SECA a call in the morning at 1 800 542 7322 if changing the batteries does not fix the issue.
You do not want to attempt a repair yourself, it is a very delicate scale, and can definitely be fixed, attempting to do it yourself could just cause it to be truly damaged beyond repair.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
  • Tim Grayson
    Tim Grayson Nov 08, 2010
    Looks like someone else has grabbed this question, let me know if you need more help here once they are done.
    Tim
How do you calibrate a Seca 334 baby scale? I have the weights but need instructions
Being a prior employee at a scale company I will tell you how to calibrate that scale the first thing you need to do is get in contact with the manufacturer once you get in contact with the manufacturer give me the part number when you give them the part number they will give you the book later on how to calibrate the scale
Aug 25, 2015 | Seca Health & Beauty
For seca 763 having problem with the display. All led segment was displayed and weight is varying.Kindly help.
Try weighing an inanimate object, is the weight stable? Maybe you're stabalizing yourself by holding on to something? That will throw it off. all weight must be on the base and not moving to get an accurate reading. If it's still unstable it need new weight sensors and calibration. Probably not a DIY.
May 06, 2015 | Seca 763 Electronic Weighing and Measuring...
I have E10.11 code on Seca 869 scale what does it mean?
I have the same problem. I sent an email to the company and got no response, frustrating considering how much this scale costs for professional use. The manual says "Excessive weight has been applied in general or on one edge. Reduce load on scales or distribute weight more evenly. Restart scales."
I've done this, and it always starts with E10.11, making it unusable. If anyone has help or suggestions, please post.
Mar 12, 2013 | Seca 869 Portable Flat Scale W Cabled...
Have had the BS 365 scale for 6 years and love it. However, it has stopped giving accurate data and instead registers different weights that fluctuate and are much lower than accurate. Would love to...
Not sure if you knew this but you can change the batteries. I had the same problem and had forgotten to change the batteries. However, the weights may still fluctuate because you need to reprogram the settings. Unfortunately, i do not remember ever having an instruction manual...
Jan 16, 2011 | Rowenta BS 350 Ultra Slim Bathroom Scale...
Wrong weight
Finding replacement parts for store bought scales can be a fun experience to say the least. I would purchase a product from Seca or Health o Meter instead. Their parts and service centers are right here in the states and are genuine about their product accuracy and costomer service.
May 08, 2009 | Conair Weight Scale "Thinner" with Body...
Balance beam wants to stick at about 300 lbs. not smooth moving
I contacted the manufacturer and here is there reply.
No need for oiling or grease, but tip the scale on its side, and look
under the base. There will be four "connection points" where pivot pins
connect to the linkage assembly; see if any of those pins or linkage
points are bent or look different from the other ones.
Then, note down the serial number of the scale located on the side of
the base, or behind the column of the scale at the top or bottom of the
column, and call our Maryland repair center at 800-542-7322 ext. 111 and
speak with Tyson Long from 9:00 AM - 4:00 PM Maryland time to describe
the issue and for further troubleshooting over the phone.
I have attached our new catalogue in PDF format as well. FYI: The model
703 is a very popular, extremely heavy-duty, high-capacity digital
column scale that is a popular alternative to the mechanical physician
scales in the gym and schools environment.
Kind regards,
William Morris
Sales Support
seca north america west
Medical Scales and Measuring Systems seca corp.
3401 Centrelake Drive, Suite 320
Ontario, CA 91761
USA
Telephone +1 909 605 7600
Telefax +1 909 605 7654
E-Mail william.morris@seca.com
Internet www.seca.com
Jan 26, 2009 | Seca 700KG Balance Beam Scale With Wheels,...
Pl2010m
This is the same problem I've seen several times. Fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they just can't keep up.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company also. I've seen a lot of complaints for this "international" company.
The fix for most of the problems on these monitors is about $8 on new capacitors (Plus shipping).
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors.
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
-Chip
May 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Seca 884 Certifiable Electronic Personal Digital Bathroom Scale Logo
106 people viewed this question
Top Seca Health & Beauty Experts
pawnpower
Ravi
Tom Chichester
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
