Question about Frigidaire PLRU1778ES Stainless Steel Side by Side Refrigerator
My refrigerator is running constantly but it does not seem to be cooling.
  • 31 Answers
Refill gas and clean the condenser.
Posted on Nov 07, 2010
My GE side by side refrigerator, model TFX25ZPit runs continuously, does not shut off, how can I fix?
My advice is usually to start simple. Take the bottom cover off and vacuum the coils that are probably covered with dust. That will help your refrigerator function better.
According to DoItYourself.com:
"Troubleshooting a refrigerator that runs continuously requires an understanding of how the refrigerator works. By definition, a refrigerator is one of the few appliances within your home that has to run on a continuous basis. If the refrigerator is not running, it will not be able to keep food cold, which will lead to spoilage and waste. The way refrigerators are built to run on a constant basis, they break down on an infrequent basis.
When a refrigerator experiences problems or seems to be breaking down, there are some steps that can be taken to troubleshoot the problem. A continuously running refrigerator is indicative of a problem with one of the components within the refrigerator that needs to be assessed in order to determine the proper fix. In order to properly troubleshoot problems with your refrigerator that runs continuously, an understanding of how the refrigerator works is in order.
Condenser and Evaporator Coil The refrigerator consists of a condenser coil and an evaporator coil. It is kept cold by a liquid coolant that is pumped between the condenser and evaporator through the use of a compressor and motor. The coolant moves from the condenser where it is cooled into the evaporator. The condenser coils inside the refrigerator can be seen on the outside of the appliance while the evaporator coil is located inside the refrigerator.
The Role of the Heater and Thermostat Frost and condensation rarely builds up inside the refrigerator. A heater inside the refrigerator melts any frost that may occur inside the refrigerator long before it ever appears. This melting of frost takes place at various stages inside the refrigerator. After the melting process that takes place with the heater, the thermostat is engaged to set the refrigerator at its proper cooling temperature, keeping frost from building up.
Identifying Specific Problems Most of the parts that make up the compressor and evaporator units inside the refrigerator, consisting of thermostats, the heater, condenser, fans and various switches, are easy to identify and replace. The trick to troubleshooting the refrigerator that runs continuously is to listen for noises and sounds that occur and seem unusual to you. A loud running refrigerator or constant churning of ice when the ice makes is not engaged can indicate problems with the motors or compressors that need to be replaced immediately.
Addressing Problems with a Continuously Running Refrigerator Nearly all problems that can be uncovered by troubleshooting your refrigerator can be fixed by most every do-it-yourselfer. Those problems with your refrigerator running constantly that involves the coils located outside or inside the refrigerator should be handled by a professional repair technician. This is because the coils contain the refrigerant that can be dangerous if you are exposed to it accidentally during the course of a repair. If you notice a problem with the refrigerator or a constant running that seems to be getting progressively worse over time, the best way to address the issue is to isolate the problem and fix it."
Apr 23, 2015 | Refrigerators
Refrigerator has frost in freezer
replace the defrost thermostat on the coils in the freezer and you will be good to go. Here is the part to order.
Feb 10, 2013 | Amana DRB1901C Bottom Freezer Refrigerator
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
Refrigerator is constantly running. Temperature on both freezer and refrige seems to be normal. About a week ago, we pulled everything out of the refrigerator, turned it off for about 5 hours and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 13, 2010 | KitchenAid (KSRD22FKST) Side by Side...
The freezer constantly drips water even with the ice maker turn off, the fan constantly runs but when the door is open the fan shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Microwave Ovens
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Hissing sound and constantly running generator
The only thing I can think of that you may be hearing would be if the compressor has a problem. If you notice cooling performance decrease or it stops cooling, I believe you will find the compressor has bad internal valves. It will probably take a technician to properly diagnose this and if the compressor has this problem the only answer is to replace the compressor.
I hope this helps, supertechks
Mar 28, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Frigidaire PLRU1778ES Stainless Steel Side by Side Refrigerator Logo
150 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
