Question about Dell Inspiron 546 MT Desktop Computer
I have a Dell Inspiron 546 running Windows Vista. When turning it on the Start button lights up, but the display very quickly goes into power saving mode. Nothing further can be done. The computer or display will not respond.
  • 2 more comments
  • fredknapp Nov 07, 2010
    Saw the Dell logo once before the power saver went to work. You have to look fast and sometimes it never does appear.
    Do you mean to open up the computer and remove the small round disk type battery?
    Please advise what battery. Right now I have all cables disconnected and computer opened up. Small round battery is in lower right corner called BAT1.
    I followed your last direction. No luck. Display immediately went into power saver mode.
  • fredknapp Nov 08, 2010
    One month beyond end of warranty.
  • Dell Master
  • 4,737 Answers
Well as per your recent comments, it seemed you've already tried removing the CMOS battery. There are many possible causes, like the Video card, the Ram, the Bios, the Reset switch, the front panel connector or even the hard disk drive or the CD/DVD drive or Power Supply unit.
First, you need to disconnect or uninstall everything from the motherboard except the Processor with HeatSink Fan and the Power Connector(s). Unplug the Front Panel connectors (the connectors which come out from the front part of the cabinet, connected to the motherboard). You need to be careful with the main Panel, i.e. the power switch, reset switch, hddled, power led. Before you unplug them, note down the connection sequence if you might forget it. Also take note of the power switch pins, you'll need to short it after a while. Unplug the HDD data and power cables, Cd/Dvd Drive's cables, and everything else. Remove the ram, remove the bios battery.
(don't remove/disconnect the system speaker)
Now, connect the power cord and the monitor on the back, power on the monitor (I would recommend you to connect the monitor via VGA), take a screw driver and short the power switch pin on the motherboard (I've mentioned this to you to take note). Look at the cpu fan and on the monitor, at least the system speaker should beep this time with the beep codes indicating that there's no Ram/Memory installed. (If nothing happens, then there's problem with the motherboard, could be the video card or could be the bios or something else) If so, then turn off and install one Ram. Again power up and check the status, if there's nothing wrong with the Ram, Motherboard, Bios or video Card, then you must see the Bios' System info screen (black screen with white texts after the Dell Logo flashes). If it doesn't seem anything happen, then try with the other/another ram. (If it fails, then there's problem on the motherboard, you better get another than repairing it.)
If it boots up with the Bios System info screen, then turn off and connect the front panel and other panels, like usb or audio etc.. Again power On the machine from the Power switch (this time On/Off switch), verify what happens. if it's ok, turn off and reconnect the hdd and the dvd drive and so on.... untill everything is reconnected and reinstalled or you'll stuck somewhere during the steps when the faulty component is installed.
Let me know the outcome, sorry, this is too long.....but I don't want you to get confused.
Posted on Nov 08, 2010
    Genius:
  • 1,035 Answers
Hi. Were you able to see the the DELL post screen when you turn on the computer? Take out the battery and unplugged the power adapter from your computer and to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn on the computer.
Posted on Nov 07, 2010
  • Angelito Rabago
    Angelito Rabago Nov 07, 2010
    Since we already did minor troubleshooting on the computer and still same issue. This could be a motherboard problem. If the computer is still under warranty i recommend to have DELL repair the issue or replace the motherboard.
How to get HDMI Connection from Inspiron 546 to LCD HDTV working?
Press the Windows key and the letter "p" at the same time, and select duplicate
Feb 20, 2015 | Dell Inspiron 546 MT PC Desktop
546 will turn on normally(light is blue) but won't display my monitor and usb ports power some items and not others.
You probably dislodged some components in your computer after it fell. Suggest that you open the computer and re-insert the memory modules and other cards inserted in the motherboard. Unplug it first and on a non static surface like a kitchen table.
Mar 22, 2014 | Dell Inspiron 546 MT Desktop Computer
Dell Inspiron Desktop 546MT, green light on the back, but no light on the front
Could be a faulty switch, switch wire connector loose from the motherboard, faulty power supply.
Jan 29, 2012 | Dell Inspiron 546 MT Desktop Computer
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
How do I download maual for Inspiron 546? I cannot open compartment to insert DVD
support.dell.com
you can find your manual there. there's more than one compartment. Try pressing the long flat button on the bottom to eject the tray (do this when it is on). You can also open the try from windows. Go to Start Menu > My Computer, right click on the disc drive and click eject.
Apr 03, 2010 | Dell Inspiron 546 MT Desktop Computer
How to access bios on Dell Inspiron 546
As soon as you turn your computer on, and see the Dell logo, start tapping the F2 key.
If you miss this window of opportunity, wait until Windows has fully loaded, then restart your computer. Try again.
(The Dell logo comes up pretty fast. If you miss entering BIOS Setup, {System Setup is Dell's term}, then as soon as you press the Power On button, start tapping on the F2 key. Tap in 2 second intervals)
http://support.dell.com/support/edocs/systems/xlob/dtg/en/systemse.htm#wp1211139
Jan 23, 2010 | Dell Inspiron 546 MT PC Desktop
#1 - just bought a 546 computer with windows 7. manual in package was for vista. how to get 7 manual? #2 how do I register my purchases?
To get the manual for windows 7, search windows 7 on microsoft.com
What do you mean by register? To activate and register windows or to register you dell computer?
Nov 07, 2009 | Dell Inspiron 546 MT Desktop Computer
Back light fine with power supply and goes off on battery.
I would need to know what operating system you are running because Vista has a setting for the display brightness when running on batteries. I would suspect that, that setting is turned down to conserve battery power. If this is not the case, then the battery may be too weak to put out the correct voltage requirements for the display. If you have Vista, go to the control panel > power options > In the left pane, look for the display brightness > here you can change the brightness for running on battery and for AC power.
Oct 14, 2009 | Dell Inspiron 1720 Notebook
How to shut down dell inspiron 530 computer - the button only takes computer to sleep mode
I assume you use Windows Vista.....
In vista the default action of the power button is configured to sleep mode..
So to shutdown the PC you can press "Start - right arrow - right arrow - right arrow - Enter", or you can navigate to the same using the mouse & selecting shutdown from the list besides the lock icon.
You can also change the power button configuration this way goto " Start-Control Panel-System and Maintenance-Power options-change plan settings (under the current plan you are using) - change advanced power settings - Power buttons and lid - Start menu power button" click on settings and select shutdown, apply & save the settings and close this window.
Now you can just click the power button to shutdown your computer.
Jul 05, 2009 | Dell Inspiron 530 Desktop Computer
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Dell Inspiron 546 MT Desktop Computer   Logo
399 people viewed this question
Clive
Clive
Alun Cox
