Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
Got a Craftsman 5 1/2 in circular saw that just started to make a grinding noise. Upon examining the blade, I noticed that it binds when I hand turn it on the shaft. I assume that this binding is associated with the grinding noise. I've had the saw for 15 yrs. and have had no problems. Checked obvious things like a loose or bent blade but all seems fine. I'm thinking maybe bad bearings??? Any suggestions?
    Top Expert:
  • Sears Master
  • 12,744 Answers
Worn or damaged bearing --brushes worn --
Posted on Jul 25, 2017
2 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: cannot tighten blade on old craftsman circular
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
Posted on Jan 24, 2011
Where is the blade lock for CRAFTSMAN 315.10951
quite possibly there is none . most people use a block of wood held against the blade.
Aug 16, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
Bolt that holds blade well not loosen what is the correct direction to loosen bolt
Remember that on a circular saw, the bolts are typically left-handed thread so it is the opposite of a typical bolt. This is because the blade spins to the right so if a normal bolt was used it would loosen as the saw operates.
Jul 19, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
To remove the circular saw, which way do you turn the nut hold the blade on the saw?
For any saw blade or grinding wheel, the rule is this. Pushing against the points of the teeth should be the direction that tightens the nut. So you must loosen it in the same direction that the blade spins. For example, if your saw blade is on the right side of your saw, then the blade spins counterclockwise, and the wood pushes against blade clockwise - so you turn it counterclockwise to loosen it (which is in the same direction that the blade spins.). If the blade is on the left side of the saw, you loosen it clockwise. Good luck, Al K
May 22, 2011 | Sears Craftsman Circular Saw Blade
Cannot tighten blade on old craftsman circular saw.bolt turns blade shaft and motor without tighting blade
Jan 24, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
Cannot remove blade from craftsman circular saw
without knowing the model number I can only assume that it is a circular saw and the blade is on the right hand side and then the bolt should be a standard thread. Hold the spindle lock in and turn the bolt counter clockwise to loosen. If other than it would probably be a left hand thread and do just the opposite. Let me know and if so please provide the model number so I can look at a breakdown for the tool.
Jan 31, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
My 7 1/4 in Craftsman circular saw stops running.
Is there anything jammed between the blade and the body/guard of the saw?
Jun 26, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Replacing saw blade
there is a spindle lock button between the handle and the blade housing, rotate the blade by hand while pushing in on the lock buttonwhen it goes in all the way the blade will be locked in position so you can loosen the bolt with a wrench
Mar 31, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How do i change the blade on craftsman circular saw?
some saws don't have a blade brake , i always take a pair of vise grips and adjust to grip blade tightly and hold or bind against housing then remove bolts works well for me
Jan 02, 2009 | Saws
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
79 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
