Re; fUJITSU t-730 Tablet PC: I wish to take the entire top "half" (containing the display, the "lid' and the entire assembly "north" of the swivel hinge) and separate it from the base. I have two of these, and want to swap the display on one with the other - for good reasons, but not germain to the question. I will say that I want to put the better screen a(bright, "wide angle, outdoor"with the better chassis (better cpu,, HDD, RAM), so if it is easier to just swap the displays, and not the entire top portion of the computer, please feel free to explain that. I have always found how-tos for display changes to appear to be "messy" at best, and given the multiple dgitizer layers of a dual digitizer screen, it seems especially dicey to swap displays. It would appear to be so "simple" - no doubt, deceptively so - to get to the screws which attach the swivel hinge to the base - or the lid - carefully pull apart all the connecting wires, swap top halves and, volia! I have the "transplants" I seek. Finally, I cannot find a service manual for the T730 or its predecessor "twin,' the T4410; the chassis for both are identical, and if you can help me find a service/repair manual, that would probably give me all the info I need
  • 1 more comment
  • Jeff Bellin Nov 07, 2010
    Thanks for letting me know about the repair manuals. Pretty sleazy move, as most other mfrs publish theirs on the web (HP, Dell, etc.).
    Thanks for clarifying that there are small differences between the T4410 and the T730.
    I do want to perform this "head transplant" because I have two T-730s, one with a Core i7 cpu but the standard screen and one with a core i3 cpu and the bright, wide angle screen, and there is a huge difference. I bought them both at the Fujitsu eBay site where you don't always get to pick and choose.
    In any event, I would love to have step by step directions. But before you get into that, please tell me your opinon; is it just a matter of carefully removing many screws, keeping track of them and separating the screen/lid from the base, or are there other components (eg, keyboard) that are tricky to get off and put back on that are required to get to the swivel hinge. I am competent to do disassembly, keep track of parts and carefully disconnect wires, but anything requiring more dexterity/expertise is beyond my ken. One of the things I read about that was a little tricky was disconnecting the very thin antenna wires.
    Anyway, if you think from my above description that tackling this task should be possible for me (one more thing: I know when I hit a task that I have a risk of causing irreparable damage and often have stopped at such a point and putting everything back from there.), I would love to have step by step directions.
  • Jeff Bellin Nov 08, 2010
    I did not hear back from the first expert, who said he would provide me with step by step directions to achieve what I want to achieve. He also told me that it is impossible for owners to get service manuals for Fujitsu products. That fact alone amkes me think twice about purchasing more.
    Nonetheless, I really do want some help as to just how to dissemble the T-730 sufficiently to get the entire lid/screen section off and swap it with my other T730's sreen.
    I would appreciate hearing if you agree with the first expert (you can easily swap lid/screens between T730s and you cannot get a service manual) and, if you agree with both, I would be happy to pay an extra fee for the how-to for this. Thank you very much.
  • Jeff Bellin Nov 09, 2010
    Sorry I couldn't get back to you for a couple of days. In the interim, a member of a forum I am active on actually sent me pictures and step by step instructions as to how to do this. You are right that it does require getting pieces off of the casing and even reremoving some connections to the motherboard, but it's actually fairly simple. My forum buddy said it took him 20 minutes to take apart and reconnect the first try and 10 minutes the second. So, I'm going to give it a whirl. Thanks for the help. You are correct about Fujitsu keeping everything very "close to the bone" - I have heard that from everyone I asked about a repair manual.
    Best,
    Jeff Bellin
    President:
  • 2,777 Answers
There unfortunately is no real service manual for either of these models, all the specs you are looking for are proprietary confidential information that only Fujitsu tech people can access. I have taken these models apart though in the past and it is far from easy.
You do need to completely disassemble to base of the laptops, opening the case and getting to the motherboard of the computers. To do that you pretty much have to "crack" open parts of the casing, around the ports such as the video out ports... In the factory they really do break the case off and just replace it when they are rebuilding it.
Sadly there is no simple way to get those screens off the hinges and swap them, and it will actual damage the casing of the laptop to even try.
Let me know what you think you want to do here... just thought I'd get this information over to you so you can make the decision
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim though.
Posted on Nov 08, 2010
  • Tim Grayson
    Tim Grayson Nov 09, 2010
    Sounds good, I definitely wish you luck, glad you found someone that has the pictures and all, that is extremely handy to have.
    Tim
  • 13,433 Answers
Hello
The fujitsu service manuals are limited to working employees and approved companies, leaking out a service manual is a violation of the agreement with fujitsu.
I'm not an employee of fujitsu and you are going to have a hard time finding that service manual.
As for the replacement job. Its definitely better to replace the whole display, If you are trying to swap out a display from T730 into a T4410, its not going to work. There are many small differences in the display, the screw positions, etc, not going to fit.
As for replacing a T730 display from another T730, that will do fine.
The cables go into the casing of the computer from the display, and you will have to take apart the machine quite alot. Your going to have to sit down and take the machine apart, make sure you got alteast two hours to figure it out.
If you want me to write instructions on how to dissasemble the machine let me know.
Posted on Nov 07, 2010
  • Ekse Nov 07, 2010
    The antenna wires are pretty easy to pop up, if you have taken apart other laptops, its the same thing or as far as I know.
    The wires might be a bit difficult to get out from the bottom of the laptop and to come out with the display, but it shouldn't be too much.
    You can definitely do it as long as your hands move and you can write on the keyboard, so you definitely have what it takes to take apart a machine. it might be a bit more difficult on getting the screen off the base, but I havent taken this machine apart myself to say for sure, it might be as easy as other machines.
    but with patience and care you can get it apart and keep track of what goes where, and since if you have done this before on other machines, I'm pretty sure you can figure it out, but don't force anything.
    About the different models again, unless otherwise stated by the manufacturer: from previous experience that you can't take a part from another model and put on another, since theres the very annoying small differences for example tried to swap the exact same looking keyboard from a acer machine to another acer machine, the cable was on the other side so it was impossible to connect but it went in just fine. Then another case was when I was replacing a lcd display on a normal laptop HP, both where HP, size the same but the screen had the screw holes on the different spots forcing me to come up with something or buy the same model screen for that laptop.
  • Ekse Nov 08, 2010
    I've responded to your message.
The dispenser drawer on my AEG Lavamat is stuck half open and appears jammed. Help please
Open the machine up on the top lid. 2 screws at the back of the machine at the top. Slide the lid back and remove it. The drawer can now be accessed. There should be a bunch of clips holding the lid of the drawer . You can carefully open these clips to remove the lid or just remove the entire drawer assembly and replace it or try to figure out what is jamming it.
Jan 22, 2018 | AEG Washing Machines
Lifebook tablet stylus doesnt work
Hello, Lori -
If you received a user's guide for your laptop when you purchased it, check the manual, starting on page 30 for instructions on using the stylus (called a pen) in the guide.
If you do not have a user's guide for your laptop, you can find and download one here (free):
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/T4220_UG_B5FJ-4091-01EN-00.pdf
You will need Adobe Reader software (free) loaded on your laptop. After you download the guide, save it with a file name you can find easily - something like: Fujitsu Lifebook T4220 Manual. If your laptop is connected to a printer, you can print the guide for easy reference.
The information on using the stylus / pen begins on image 40 (page 30) of the PDF document.
Information from page 31 (image 41 in the PDF document) regarding the pen:
CALIBRATING THE PEN
In order to ensure accurate tracking between the pen
and cursor, you must run the Touch Screen Calibration
Utility before you use the active digitizer for the first
time, or after you change the display resolution.
To run the calibration utility:
1. Go to Start -> Control Panel and double-click on
the Tablet and Pen Settings icon.
2. Click Calibrate.
3. Adjust the display of your Tablet PC to a comfort-
able angle.
4. Using the pen, firmly touch the screen directly on
the (+) symbol; the (+) symbol will move to the
next location.
5. Repeat step 4 in the four corners, then click OK.
Best wishes.
Feb 09, 2018 | Fujitsu Computers & Internet
The spinner is not rotating and is making weird noise.
If this is a TOP LOADING Roper washer, a no spin problem can have several causes. However, most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair it yourself:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers (such as Roper) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool, so these instructions do apply.
Mar 25, 2010 | Roper RAX4233PQ Top Load Washer
Agitator will not spin
If this is a TOP LOADING Whirlpool washer, a no spin problem can have several causes. However, most commonly, this is caused by either a lid switch malfunction or a broken motor coupling. The following link explains how you can diagnose the problem and repair it yourself:
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
Replacement parts can be purchased at any of the following websites:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. The agitator parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
NOTE: These are very easy and inexpensive repairs that do not require the assistance of a repairman. The average cost for the entire cam replacement kit and/or motor coupling is about $15. The lid switch runs about $25 - $35.
Mar 19, 2010 | Whirlpool Washing Machines
Top part of agitator does not rotate (bottom part does)What's the fix? Can I do it myself? Should I get a repair service?
If this is a Whirlpool manufactured top loader (such as Kenmore), the problem may be a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
repairclinic.com
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you. NOTE: This is a very easy and inexpensive repair that does not require the assistance of a repairman. The average cost for the entire cam replacement kit is $15.
Mar 11, 2010 | Kenmore Washing Machines
The agitater will not turn unless I push down on it
If this is a Kenmore top loader, the problem may be a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
Whirlpool manufactured washers (such as yours) uses a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
repairclinic.com
If you have any questions, please post back with a MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) if it is different from the one you posted this question under. I hope this helps you.
Feb 21, 2010 | Kenmore Washing Machines
My agitator doesn't turn like it used to
If this is a Whirlpool manufactured top loader (e.g., Kenmore, Estate, Roper and some later model Maytags), the problem is either a worn agitator cam assembly or worn agitator dogs. The following link explains what agitator dogs are and how to access them:
Whirlpool uses a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembyl which includes the dogs, the cam, the cam seal and thrust bearing.
repairclinic.com
Feb 18, 2010 | Kenmore Washing Machines
The agitator sounds like it is grinding and shacky. It is not agitating properly
If this is a Whirlpool manufactured top loader (e.g., Kenmore, Estate, Roper and some later model Maytags), the problem is either a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
repairclinic.com
Feb 18, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Krups Vitamight model 294 juice extractor. My son used it and now I can't get the pulp container off. I have never used it and the the manual is gone.
i was having the same problem and couldn't find it anywhere... finally figured out that you twist the top off. place the unit with front towards you.
pull/twist the right side (pulp catcher) towards you about a quarter turn and the entire top comes off including the sieve.
Nov 20, 2009 | Krups Juice Extractor
Fujitsu stylistic used just came - where is turn on button?
Holding it so the display looks towards you, LEDs on the bottom, row of six buttons horizontal on top left, it's on the left border, about 1/5 from top.
Nov 04, 2009 | Fujitsu Siemens Stylistic ST5021D Tablet...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
