Ok I have a major problem... I have tried everything i can think of. My machine is the ASKO W6221. I put a load in to wash and it washed fine but when it came to the draining part it doesn't work. It just makes this rattling sound, sounds like there is some change or pebbles rattling around in the bottom or something, then it just hums and no draining happens. I tried setting it to #11 the "Drain" cycle but nothing happens just the sounds I described. Now I have a load of laundry stuck in there and there is water in the bottom so it wont let me open the door! What do I do... my favorite jeans are in there! I'm having the same problem, with the gravely noise. The expensive repair guys came out, said it needed a new drain pump and 3 weeks later came to put the new one in. It does the same thing!. Their conclusion: faulty part. I'm skeptical. I'd like to check to make sure there isn't something caught behind the pump. any thoughts?
Drain is blocked
Sounds like a blocked drain you need to remove the cover to access the bottom drain hoses
remove bottom drain hoses and inspect hoses and drain
even inspect the pump its on the opposite end of the hose to the bottom drain
if you get stuck i will try to help you further
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If
your washer spins but doesn't pump the water out, the drain line is
probably clogged. In many washers, a small sock or other piece of
clothing can get between the clothes tub and the outer tub that holds
the water. If the clothing gets between the tubs, it may then get into
the drain hose that's attached to the pump--or even into the pump
itself. If it's in the pump, you need to remove the hoses from the pump
and pull the item out.
To remove the sock from the outer tub
port, open the washer's main access panel and remove the large-diameter
rubber hose that connects the pump to the bottom of the outer tub.
Then, using needle-nose pliers, try to grab and remove the clothing
through the port.
Sometimes you can't remove the stuck
clothing from below. Then you have to remove the agitator, top of the
outer drum shield, and inner clothes tub. This isn't easy to do--and
you may need special tools--so you might be happier getting a qualified
appliance repair technician to do the job.
If the drain line
isn't plugged, the problem may be with your pump. Even if the pump
appears to be turning, the internal impeller may be broken. If so, you
need to replace the pump.
If
your washer doesn't spin or pump water out but the motor is running,
your washer probably has a frozen pump pulley. If so, you need to
replace the pump. To check the pulley, remove the pump from the washer
and try to rotate the pulley manually. If it doesn't turn freely--if
it's frozen or stiff--replace it.
If
the water that pumps out of the machine goes back into the machine
after the spin cycle, your washer may be siphoning the water from a
laundry tub that has a slow drain, back into the washer. The usual
remedy for this is to improve the draining of the laundry tub. (Is
something stuck in the drain?) Also, check for these problems:
Now coming to the humming noise issue please CLICK HERE and follow some troubleshooting steps mentioned.
Another thing your problem is a major one and it will require a physical presence of a tech to get it fixed.
Goodluck..
