Question about Sony Playstation 3 (PS3) Console
Broken PS3 Hi, I have the same problem as the other guy had (the PS3 doesn't work on a normal scart/av tv, but it does on an hdmi tv). You said to "turn off the power and hold down the power on the system". what do you mean by this? You can't hold down the power as it is a flick switch, it stayes down. Do you think you could explain it to me in more detail? P.S: Sorry if I sound stupid.
  • arthur94 Jun 15, 2008
    Sorry, worked out what you meant, but that only gives me audio, any idea on picture?
    Champion:
  • 207 Answers
Try it 4-5 times! It took me 8 to get this ps3 up and this was number 12 I fixed this week... killer
Posted on Jun 17, 2008
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
Scart signal
check the tv mode av1 av2 and pal settings
Sep 05, 2008 | Televison & Video
My ps3 will not put out any audio or video
Have you changed your settings from hdmi back to normal you should try both hdmi and scart or av on your tv, if this doesn't work then you need someone with a ps3 that works (you need your ps3 and a spare tv) and you can copy what theres does but you need to be very precise or look on you tube to see how to restore your ps3 back to the factory settings. I hope this helps mines done the same and it worked for me.
Apr 04, 2012 | Sony PlayStation Video Game Consoles &...
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
I bought my ps3 slim and panasonic viera tx-p37x20b in the same day and first of all i connect them on scart cable. Next day i bought HDMI cable connect to tv and no reaction so connect again scart and...
First of all, i think U idiot.2nd lrn speak! its time for you go school. 3d of everything i can think of noaw we have same problem psn: somentus
Nov 14, 2010 | Televison & Video
Hi,made connection by use of HDMI cable from ps3 to tv with no problem.But now i wont to conect to tv which doesnt have aHDMI point.So i have got a SCART Lead which conect to ps3 to tv and i have an AV...
turn on your ps3 (with your tv also on) and hear the ps3 start power beep. after you hear this normal beep, press and hold the power button for 5 seconds till you hear a beep then let go of the button.
This will reset the outputs and resolution to defaults and you should get your display again, if you don't then the ps3 has a fault.
Jan 02, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection
With your PS3 on standby (red light) hold the on/off button down until it goes green and then back to red. This restores your PS3 to "factory settings", i.e. it is waiting for you to tell it how you want it to connect to your TV. Now disconnect any HDMI cables you may be trying to use and connect your PS3 to your TV via a scart connection. Now switch your PS3 on and turn to your AV channel and you should have both sound and pictures.
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 No picture or sound
When you connecting sony via hdmi sony and tv must be shut down.First turn on sony then tv.Connect also and av cable or scart then go to sony settings and change out signal via hdmi or scart or av cabel and confirm.That should work
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
