Question about Whirlpool Refrigerators
Whirpool "gold" model GSF26C5EXW00 is
Our Whirlpool Gold model number GSF26C5EXW00 had the same problem. The ice maker seemed to randomly work sometimes, and not other times. Sometimes if I moved my food around in the fridge, it would make the ice maker work. Anyway, two service calls later, the Whirlpool tech told us that it is a VERY common problem with this model (which is exclusive to Lowe's apparently) and that the water line just freezes on it's own. Beware! We now have water dripping down the back of our freezer (inside the freezer) and it's sizzling on something at the bottom of the freezer. I've contacted Whirlpool and told them it's a lemon. Literally 11 months old and so many problems? We're demanding that they replace our fridge with another model. I don't trust his one at all...
Posted on May 19, 2011
I'm had the same exact problem. I travel and my wife would told me the ice maker wasn't working, but when I arrived home it miraculously worked. This happened many times over the last six months. Well, I didn't travel this week for my job, and my ice maker hasn't worked the whole week. The engineering in this fridge is definitely faulty. I'm past the 1 year mark too. I'll contact Whirlpool, but can only imagine where I'll get. Buyer beware....
Posted on Jul 29, 2012
  • shannonpenla
    shannonpenla Jul 29, 2012
I also have a whirlpool gold purchased through Lowes. 3 months new and stopped making ice and dispensing water. 4 service calls later, a part was replaced. I was also told there were problems with this model. 10 months later, no longer making ice and water again. I did not buy the extended warranty.
Has anyone been able to pursuade Whirlpool to replace?
Posted on Jan 18, 2012
Why does ice maker does not dump ice into door bin?
Lynn you have to give make model and other details that will facilitate a proper answer.
Jul 04, 2015 | Refrigerators
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
I have a Whirlpool White Conquest Side-By-Side Refrigerator GS6SHAXLQ03, manufactured March 2003. The ice maker creates ice and fills the "holding bin" on the interior of the door. However,...
The ice will melt during the defrost cycle. Make sure your freezer is cold enough, at least -5, preferably -10. also, if your freezer is not full of food, put some milk jugs full of water in there to take up space. This will keep the temp colder when the compressor shuts off for the defrost cycle. if there is too much empty space, there is not enough mass to stabilize the temperature and keep it cold.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Admiral side by side, the ice maker does not seem to making ice
Pull down slightly on the bottom bin lip , and pull the bin foreward . The bin has to lock in place , or it would slide foreward , each time the ice dispensor is used , causing the freezer door to be pushed open from the force .
Jul 11, 2009 | Maytag Admiral Top-Freezer Refrigerator
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Ice maker makes ice but doesnt kick it out
seem likes the heater on the ice maker mold is not working , you'll need to replace ice maker
Dec 15, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by Side Ice Maker Not Making Ice
sometimes if you use the water filer too long and don't change, can cause this problem.
Jul 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
905 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
