The lights on the left side of the clock are flashing on and off...upper on light, preheating light and cleaning light..one light at a time and then all three at once...it is repeating this sequence.
Re: The lights on the left side of the clock are flashing...
Hi If you have already replace the oven temp. sensor and it is getting 1100 ohms then the electronic control is bad and should be replaced. This occurs when a component goes bad in the electronic control board. Please let me know if you need more help. Daniel
How to change lower element in DeLonghi Airstream Convectio Oven??
Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Sounds like a circuit board issue. If in Warranty, contact the manufacturer and have the controller replaced. A routine cleaning has noting to do with the normal operation of the baking or broiling function. Cleaning is disengaged after the door is unlocked and ready for general aplications.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
The clocks tell the stove when to start and stop. Has you set the timers right? In other words if you have the start time set to 6pm and it is now 2pm the clean cycle cant start for another 4 hrs.
You could possibly have a bad control switch. But first check all wiring from the receptacle, plug (wires all connected), wiring to the back of the oven. I am hoping that their is not a bad circuit board.
