Question about Toshiba CZ36V51 36" TV
Hi, I've a Toshiba CZ36V51 36" TV that won't power
  • 275 Answers
SOURCE: green vertical line
This is generally the case when the Horizontal Yoke Coil is defective.A defective Hor. Deflection Coil bad is very very rare. 9 cases out of 10 it is a dry / bad solder.If you are versed in Solid State Electronics, I advise you to Unplug the TV and carefully open the back panel. There will be a Coil mounted on the neck of the Picture tube. It will have 4 connections and there will be 4 wires leading from it to the Main PCB. Check these connections - both on the Coil and on the Main PCB. If these are OK, then call in a qualified Technician.Nothing more you can do.
Posted on Jun 09, 2009
bluegreenash
  • 661 Answers
SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Posted on Oct 15, 2007
  • 1694 Answers
SOURCE: hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Posted on Nov 27, 2007
  • 1153 Answers
SOURCE: Toshiba, gray screen with thin lines then dead.
Was the circuit board damaged?
Posted on Dec 27, 2007
3bachelors
  • 52 Answers
SOURCE: Toshiba TDP-S8 Projector Inoperative
I have the same projector, and had the SAME problem.
After unplugging and taking on a trip it didn't work...it just lit up for 2 secs, and then shut off....
LEAVE it plugged in for as long as it takes for the light to stop blinking, and then it should start up on its own, or if you press the on/standby buton.
Be patient, hope this works for you too!
Posted on Sep 03, 2008
Why has my Toshiba flat screen tv got a broad green horizontal band across the top?
One of the circuit board ribbons connected on the vertical control is probably loose there is a few vids on you tube for this repair , failing that some of the driver capacitors need replacement with higher voltage caps same microfarad.
Oct 15, 2014 | Toshiba Hi-Def Flat-Screen Lcd/Led TVs 32"...
Toshiba 32AF45 CRT TV Distortion and Flicker During Moments of High Contrast?
Check its main power regulator section circuit. Replace all the electrolytic capacitors there. This is a power supply fault.
Mar 21, 2013 | Toshiba 32AF45 32" TV
I have a Toshiba Regza 47ZV650U 47" LCD TV that
I am having the exact same problem with my 47ZV650U, what was you solution
Jul 13, 2011 | Toshiba Televison & Video
Toshiba 19inch lcd tv green line down screen
A solid line down or across the screen is due to problems in the display itself. Unfortunately, there's no way to repair it because the bad circuitry is integrated into the display. The only cure is display replacement.
Not the solution you want, but that's how it is. (With the huge number of transistors that are part of the display, it's actually amazing there are as few failures as there are.)
Jan 22, 2009 | Vizio GV42L 42 in. LCD Television
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba CZ36V51 36" TV Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
