Question about Uniflame 200209 Open Flame Patio Heater
I have a Blue Rhino Uniflame 200209 model deck heater. I have replace the valve, the pilot light, thremocouple and the ignighter. The propane tank is also full, I just had it topped off a week ago. The heater will light the pilot light and even when you leave it ignited for five minutes and get ready to turn the unit on low it extinguishes the flame and will not ignite. I don't know what to do to repair the heater. Any suggestions e-mail me at jmarlar@windstream.net. Thanks
    Champion:
  • 274 Answers
Try replacing the regulator and hose, the regulator may not be allowing enough gas through to light the main burner.
Posted on Jul 22, 2011
Where do i get a book or assembly instructions also need igniter
Uniflame Patio heaters are manufactured my Blue Rhino. You can find what you need at the following link. http://www.uniflame.com/BRWEB/getdoc/74bac003-eaff-41fe-9d7c-7b02c79b6c3b/Outdoor-Heaters.aspx
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Uniflame 200209 Open Flame Patio Heater
Burner lights but then shuts off after about a minute
What's happening is a good indication that the pilot assembly and the burner assembly may need cleaning. Insects can really clog it up. If after thoroughly cleaning the pilot and burner assemblies the burner still shuts off,check the gas tank and make sure it's at east 2/3rds full. After reconnecting the hose to the tank, open the tank valve VERY, VERY SLOWLY (Slow motion, slow) until the valve is full open. Then attempt to light the pilot and the burner. If every things works as it should, you solved the problem.
If you find you need to order a thermocouple, I have provided a link to the Blue Rhino Company, the manufacturer of Uniflame Patio Heaters and you can order it thru them.
http://www.uniflame.com/BRWEB/getdoc/3dbb047b-509e-4627-98cd-c4cdb36d82a9/Parts-and-Accessories.aspx
I hope this helped you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 15, 2011 | Uniflame 200209 Open Flame Patio Heater
WHERE CAN I GET A REPLACEMENT HEATER ASSEMBLY FOR THE SUNJOY L-PH018PSS
Bruce, Blue Rhino is the manufacturer of your Uniflame Patio heater. You can get replacements parts from them, by contacting their Customer Service Dept 1.800.762.1142
Hope this helps and thanks for choosing FixYa.
Jul 31, 2011 | Uniflame 200209 Open Flame Patio Heater
The Sunjoy MLPHO18PSS will light but will only stay lit for about 15 minutes and then it goes out. We've replaced the propane tanks thinking it was low but that wasn't the case. Thank you! shar...
More than likely, the Thermocouple is loose where it attaches to the control valve. Or the Thermocouple is going bad.
Sunjoy is manufactured by Uniflame, which is owned by Blue Rhino Corp.
If you end up needing to purchase a new Thermocouple call 800-672-1142
Hope this helps resolve your problem.
Feb 26, 2011 | Uniflame 200209 Open Flame Patio Heater
I need to convert a Endless Summer Blue Rhino patio heater Mod. No. 233010 from naturalm gas to propane , what do i need
You would need new pilot and main burner orifices. You would also have to ask the dealer/manufacturer if the valve on the propane heater will work with propane. It may not because the propane tank will have to be connected to the heater using an LP hose and regulator. You would then need to take apart the heater to install the new orifices. Considering the cost of a new heater that is set up for LP, I do not believe the conversion to be practical.
Feb 24, 2011 | Blue Rhino Uniflame - 233010 - Endless...
Pilot light will not stay lit, even after holding for the required 60 seconds. Need manual and replacement parts.
Go to the Uniflame Home web page and you can download the Owners Manual for your heater in a pdf format. You can also order parts or find a dealer in your area that stocks parts. Uniflame is owned by Blue Rhino.
Jan 26, 2011 | Uniflame 200209 Open Flame Patio Heater
I have a sunjoy patio heater and i can light it be after about 30 seconds it makes a click noise and goes out like gas is cut off. What is the problem and where can i order parts?
The thermocouple needs to be replaced. If you still have your Owners Manual it will show you a parts breakdown and how to replace it. If you don't have it, go to the Uniflame home page and search for the owners manual for that model heater. You then can download it in a pdf format.
I believe the website address is www.uniflame.com. Uniflame is owned and manufactured by Blue Rhino.
Jan 24, 2011 | Uniflame 200209 Open Flame Patio Heater
It does not light either by pilot light switch or with a match
If you are sure that your propane tank is not empty you may have a safety feature malfunction. Unscrew the propane tank. wait two minutes and then reinstall the tank. That will reset the safety feature.
Oct 08, 2009 | Blue Rhino Uniflame Patio Heater Stainless...
Pilot is lit for 30 secs but when I turn the knob for the big fla
You have a white scale buildup in the gas valve outlet blocking the main gas flow. Take the valve apart and clean it.
Jun 14, 2009 | Uniflame 200209 Open Flame Patio Heater
Problem getting patio heater to light
the little tube that is in the path of the flame is a capillary tube that houses a thing called a j-k thermocouple. it is nothing more then a millivolt generator that produces a very small dc voltage that actuates a very small electromagnet in the main valve. when you start the unit you need to push in a button, correct? when you release the button the valve should stay open, but you say it doesn't. the millivolt generator needs to be replaced. try doing a search for "dynaglow" heaters or www dot desatech dot com for a new generator.
Dec 02, 2007 | Uniflame 200209 Open Flame Patio Heater
Uniflame 200209 Open Flame Patio Heater Logo
200 people viewed this question
Top Uniflame Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mike
Are you an Uniflame Heating and Cooling Expert? Answer questions, earn points and help others
