Question about Williams 1403622 Gas Compact Heater
On my williams wall furnace Model # 1403622 the pilot wont stay light, how do i fix this?
  • Williams Master
  • 43,501 Answers
The problem is with the thermocouple.... this is the metal thing that the pilot flame hits when it is burning....if the flame is not hitting it then it does not get hot enough...
make sure the flame is hitting it....if not then adjust the hood over the flame to get it on the thermocouple...
If it is hitting it then replace the thermocouple....for that heater though the thermo is probably and OEM part and may have to be bought from the manufacturer...
heatman101
Posted on Nov 07, 2010
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Williams wall furnace model 5009622A pilot light will not light
make sure the thermocouple is sitting 3/8 to 1/2 inside the pilot flame when lighted. if it isn't, it wont generate enough dc current to keep pilot on
Dec 30, 2014 | Williams Heating & Cooling
I have a William Furnace model #1403622 and the pilot won't stay lit. I keep reading it may need a new thermocouple but where do I buy it and how much does it cost.
Hello, you can buy a thermocouple at any heating and cooling store, they cost between 7 and 15 dollars depending on the length of it.
Mar 25, 2011 | Williams 1403622 Gas Compact Heater
We just purchased a Williams 1403622 natural gas heater and installed it yesterday. However, the pilot light WILL NOT light. Can you help?
If you mean that the pilot light does not stay lit, you could have a bad thermocouple or a loose connection at the gas valve. Make sure the flame is against the thermocouple. If you mean that the pilot won't light at all, bleed out the gas line a bit more.
Mar 07, 2011 | Williams 1403622 Gas Compact Heater
How to turn on pilot light
http://shopfnc.com/pdffiles/williams2man.pdf
Here is the installation manual that includes a section on how to light the pilot on your specified Furnace "Williams 1403622".
Let us know if this was helpful to you. Good Luck in your endeavor. :-)
Mar 04, 2010 | Williams 1403622 Gas Compact Heater
Pilot Light won't stay lit on wall furance
The low voltage wiring and the thermostat has noting to do with the pilot function of the wall furnace, check to see if when you have the pilot lit manually, while holding the button in does the flame impinge on the thermocouple and does the flame try to wrap around the thermocouple? if not the thermocouple and pilot flame need to be adjusted so that it impinges on the TC, if it does have a good flame impingment, then you probably have a bad TC from the factory, call them and have them send you a new one if still under warrenty.
Jan 20, 2009 | Williams 1403622 Gas Compact Heater
Pilot wont' stay lit
try clean pilot ..... replace thermocouple on heater
Nov 10, 2008 | Williams 1403622 Gas Compact Heater
Pilot will not light
The Pilot indicator will appear to line up with the arrow on the base, and even push in as though allowing gas to flow, but if it is just 1mm out of alignment, no gas will flow. So the solution is to move the valve in the Pilot mode slightly in one direction or the other to see if/when gas flows.
Nov 06, 2008 | Williams 1403622 Gas Compact Heater
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Williams 1403622 Gas Compact Heater Logo
619 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
