Question about Garden
Have a Miller Thunderbolt AC/DC welder wired 460V single phase and I want to know if I can wire it for 230V single phase.
5 Suggested Answers
GiantTechGuy
  • 25 Answers
SOURCE: my giant wse 200 tig inverter single phase AC/DC
Hi, remove the machines cover with the machine unplugged then look for disconencted plugs etc within the machine. careful where you place your bare hands.
Posted on Oct 18, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Need power input wiring diagram for 230V use
you can get the manual here:
http://www.millerwelds.com/service/locate_om.php
Posted on Jul 24, 2010
  • 1082 Answers
SOURCE: I bought a Miller Thunderbolt
Here is the location to find your manuals. Your serial # did not show a manual, search by Model name... http://www.millerwelds.com/service/ownersmanuals.php?model
Posted on Nov 28, 2010
heatman101
  • 43501 Answers
SOURCE: Ac compressor motor is wired
Most cannot be rewired... but some can... before I can help I do need to know the make and model though...
heatman101
Posted on Apr 27, 2011
What are some good things to look for when purchasing an used thunderbolt ac/dc cc stick welder
cc 230 isnt a bad welder. If it will be used for industrial purposes than i would go with a 440.
May 19, 2014 | Miller Welding Tools
Electrical wiring
The CP-300 and CP-200 were never designed to run on single phase. You can buy a 3-phase generator (see military surplus) or a phase converter. You will need a pretty big one - like one rated for 20hp to use the full potential of the welder. That is also pretty expensive - say $1000. However, if you have a shop, you can buy used 3-phase equipment sometimes significantly cheaper than 2-phase stuff. So you buy that expensive converter and save money on all the other equipment you will buy. Or sell it. Or scrap it - some older welders had big copper wound transformers - a few hundred bucks worth of copper.... some had aluminum though... Good luck.
Jul 08, 2013 | Miller matic 140 Mig Welding Package W/As...
I need parts for miller thunderbolt XML stick welder#903642 were can I find them?
try you local welding/metal fabrication store. not sure where your located but pretty sure Oxarc will have what you need
Apr 12, 2013 | Miller Welding Tools
Wiring a welder 480v to 220
I ahve a linclon ideal arc 250 welder which is 480V 3 phase I would like to change it over to 220V single, what are the procedures.
Mar 03, 2013 | Miller Welding Tools
I just need to know what my sp250 idlearc lincoln mig welder is single phase or three phase, my gurage has three phase running in how do i wire in ,if single phase
Hi:
Your Machine is single phase, and it could be a 208/230V or a 230/460/575V depending on the model. Check what kind of voltage do you have at your garage first, before attempting to do the following:
On a three phase wiring you will have 4 wires with the following colors; green, red, white and black. If you have 208/220/230 volts available at your garage you can connect the green, white and black wires, always green being the ground cable in the middle, black and white don't matter which side you screw them in.
Before attempting to connect a 480V to the machine check machine's plaque information in the front (or back) for real voltage, because this voltage can burn the PC board of you machine. The same color sequence applies to the 480V.
Good luck.
If this was useful to you, please vote.
Mar 19, 2011 | Welding Tools
Jul 23, 2010 | Miller Electric Manufacturing Electric...
I have a miller cp 300. It is wired for 3 phase power. I need to hook it up to 230 volt power. How do I do this correctly.
You cannot do this... 3 phase and single phase cannot be inter used... see 3 phase is 440 V AC, single phase is 230 Vots AC. This is unless the unit has Dual capability, in this case the wiring could only be wired to a Single Phase. of the unit. You will need a slow blow breaker of the correct rating and also the cable must be similarly CURRENT rated. If it IS only 3 phase, you can purchase after market single phase to 3 phase converters, that will allow you to plug the 3 phase into a single phase circuit and work, they quite costly though.
Mar 22, 2010 | Welding Tools
I have a miller thunderbolt 225v AC arc welder
The blank should be the grouDING conductor (green) and they may have a green screw to further indicate it.
Since the welder runs on 220, either of the hot wires can go to either of the other terminals (X or Y).. Those wires might be black, red, blue, brown.
There is a slight chance it would be white even though it is hot on the portable cord because some portable cord is used that way.
VERIFY the receptacle you connect to is wired correctely before connecting your unit to it.
Jan 24, 2010 | Miller THUNDERBOLT XL 225 AC 230V 50/60 HZ...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
