Question about Maytag Bravos MVWB400V Washer
Water is leaking from the bottom of my Maytag Bravos MVWB400 during the wash cycle. The hoses are all fine and not leaking.
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
GodBlessU
  • 3513 Answers
SOURCE: water leaks during final spin cycle only
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Posted on Aug 10, 2009
BIKER T
  • 909 Answers
SOURCE: Maytag Washer leaking from the bottom
It will be the normal trial and error. Remove the top lld and the back panel.statt the wash again and start looking for anything obvious. Start from the soap box, then carefully look down the sides and then if nothing seen, switch machine off and tilt machine untill you can see the underneath. Look for any areas where there is water .(when visible start looking a little higher untill you find the spot.) Most of the underneath areas are likely rust spots that have broken through.. On occation the pipes are perferrated and have a small leak. All observation.
Posted on Sep 23, 2009
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
My Maytag bravo is leaking out of the rear left side, any ideas?
I think I'd be checking the dispenser in the left rear for a crack or rub mark. Also the hoses going to and from the dispenser. They are plastic and fragile.if the top has been lifted or an extremely
off balance load ,one may be damaged.
Jan 18, 2015 | Maytag Bravos MTW6600T Top Load Washer
My top load Bravos washing machine wobbles during spin cycle.
Most likely suspension rods and bushings need replacing. Also check outer tub ring. Sometimes it will break from beating on sides of washer, behind where water comes out.
Sep 30, 2017 | Maytag Bravos MTW6600T Top Load Washer
I have Maytag Bravos washer, which displays an HC code at the end of the wash cycle. However, it has been working fine for months, and the hoses are in the correct places. What should I do?
Apparently your hoses are switched, it means you rinse cycle is pumping in hot water instead of cold. Turn off the water to the washer, switch hoes connections to washer or the wall, not both. This should fix the problem..
Good Luck
Jul 15, 2011 | Maytag Bravos MVWB400V Washer
My Maytag Bravos washer is leaking during the spin cycle. I have checked all of the hoses.
Water shroud punctured. Do not use machine.
Highvoltage+Water risks electrocution.
Oct 24, 2009 | Washing Machines
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Maytag Bravos MVWB400V Washer Logo
241 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
